997 GT2/GT3 Forum 2005-2012
997 GT3 MKII info from W.Rohrl
Old 11-11-2008, 04:51 AM
Turbo4ever
Turbo4ever's Avatar
Thumbs up 997 GT3 MKII info from W.Rohrl
Schedule September 2009 - GT3 RS less than 1 year later and few mods
3.8 L DFI engine
435hp
NO pdk,only manual
New rear wing that allows 100kg of downforce
There will be RS again! So GT3 RS for me please!!
Old 11-11-2008, 06:16 AM
Gradus Futura
Gradus Futura's Avatar
I dont understand your question. I guess to show that they are a cool way of saying, "Hey im an RS". hehe I maybe wrong(please correct me if I am), but I think RS means Rally Sport. If you look for a thread also here in the 7GT3/GT2 called, "Awesome rallye shot ". You will see a porsche GT3 rally car in action.
Old 11-11-2008, 09:42 AM
SpeedGeek
SpeedGeek's Avatar
Ford RS - Rally Sport
Porsche RS - Renn Sport
If 435 hp is correct, then the new engine must have a lower redline than the current engine. With DFI plus an increase in displacement, the new engine must make quite a bit more torque. That would translate to a bigger gain than just 20 hp unless it lacks the revs.
BTW, I told you guys the GT3 would not get PDK. I still think the reason is weight (although if the GT1 engine is retained, maybe PDK is not even compatible?).
Old 11-11-2008, 10:22 AM
KINGSRULE
KINGSRULE's Avatar
No PDK in the GT3 variants is a huge mistake.
I for one, want the latest technology in a leading edge car. If it makes the car faster to drive, I want it...
997gt3north
997gt3north's Avatar
When I heard the 3.8 and 435hp numbers a few weeks ago that was exactly my thought - would have to be 8200rpms - if it is 8400, then it is either very conservatively rated or the tuners are going to be selling lots of flashes to unlock 20whp or more - that engine on good gas at 8500rpm has to be 450+hp
Old 11-11-2008, 10:44 AM
WSH
WSH's Avatar
3.8 vs 3.6 = +5.56% so straightline would give 438 hp
I think you guys are correct, they are "de-tuning" the A91/ non-dry sump motor vs current GT1 block
Dont forget the reason the 996 & 997 Turbo/GT2/GT3 have the GT1 block is because when the "new" M96 engine was Turbocharged they all went ker-blam-o (do a search on articles from '99 and '00...Porsche tried to turbo the M96 and they all exploded)...my guess is they are playing it safe with the A91 wet sump GT3 engine. Who knows, RMS leak on the GT1 block may be a minor issue.....
Old 11-11-2008, 11:12 AM
SpeedGeek
SpeedGeek's Avatar
And that's ignoring DFI which, conservatively, should add another 5 - 7 percent, making a total of around 460 hp.
Old 11-11-2008, 11:28 AM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
At a Porsche Cars presentation about a month ago, I asked if the 9A1 engine would be used in the GT and race cars and was told yes. The 3.8 S engine is 385 HP. The GT3 engine at 435 is a 13 percent increase. The redline of the 9A1 is a lot lower than the current 8400 RPM on the 997 GT3. I suspect that it might not be raised as high which would explain the 435 HP instead of the expected 450+. Porsche also allows room for future power increases as each model year seems to show a slight power bump.
As speedgeek observes, the increased displacement with no other changes to the GT1 engine should yield 438 HP, with DFI yielding further increases. This suggests to me a lower red line with better mid range torque. On the other hand we may still see a GT3 with 450 HP. We were given a technical presentation on the new engine and it is quite impressive. The balance shafts are gone (that itself yields a power increase). The failure prone IMS is gone and the case is all new along with the heads.
I am still betting on a GT3 with PDK, perhaps reserved for the RS version since it improves track performance and both the Lambo and Ferrari offer one as will the R 10 Audi.
Old 11-11-2008, 11:48 AM
Turbo4ever
Turbo4ever's Avatar
Test driven the new C2S yesterday, I have to say the new engine is great. So I have no doubt about the new GT3 RS engine, and I am glad they will use it on their racing cars.
I don't think the PDK will reserved for the RS, because that thing is heavy.
Old 11-11-2008, 11:53 AM
C.J. Ichiban
Platinum Dealership
C.J. Ichiban's Avatar
Received 2,062 Likes on 581 Posts
3.8 L DFI engine
435hp
NO pdk,only manual
#1- I told you so.
#2- 435hp= porsche is behind the curve again...what *******.
Old 11-11-2008, 12:53 PM
SpeedGeek
SpeedGeek's Avatar
Audi R8 / R10, Lambo and Ferrari use single-clutch systems, not double clutch. Ferrari and Audi use double clutch systems on their less performance-oriented cars where weight matters less. I just can't see Porsche adding 80 lbs to the RS by means of PDK. Kinda defeats the purpose of the lighter RS.
Old 11-11-2008, 02:13 PM
GrantG
GrantG's Avatar
Received 4,983 Likes on 2,817 Posts
I think this was done so Porsche could go without the expensive Titanium conrods. One of the unfortunate things about a lower redline is that with only 6 gears and a nearly 200mph top speed, gearing will be sub-optimal for most road courses (worse than the current sub-optimal gearing).
Old 11-11-2008, 02:42 PM
SpeedGeek
SpeedGeek's Avatar
Grant, if the GT3 forgoes Ti rods, then where is the extra 50+ hp coming from compared to the Carrera motor? What will make the GT3 engine different from the Carrera one? How will Porsche justify the hefty price penalty for the GT3?
Old 11-11-2008, 02:51 PM
GrantG
GrantG's Avatar
They will likely set the redline around 7,800-8k rpm and improve breathing and exhaust (maybe bump the compression a bit higher too). It is basically like the X51 kit for the 997.2. They used to charge $14k for that alone in the past. So, now they add an aerokit, a sport suspension, bigger brakes, and a GT3 badge. No trouble coming up with the additional premium for the GT3...
Old 11-11-2008, 03:26 PM
Turbo4ever
Turbo4ever's Avatar
So how about the RS?
Quick Reply: 997 GT3 MKII info from W.Rohrl
