997 GT2/GT3 Forum 2005-2012
MPSC wear Q
Old 04-17-2008, 02:36 PM
MJones
MJones's Avatar
Default MPSC wear Q
On the front-
Would this tapered wear of the treadblock be caused by a overinflation??
Old 04-17-2008, 02:44 PM
OldGuy
OldGuy's Avatar
How many miles?
I run like 30# on the fronts and they look brand new compared to the cooked rears
I just replace. I was thinking I might get 3 sets of rears for one front
till I start hitting the track. Right now the whole set looks brand new.
5500 miles total original fronts and 2nd set of rears.
Old 04-17-2008, 05:03 PM
Kevinlpl
Kevinlpl's Avatar
No.
It is from not enough Neg Camber.
Old 04-17-2008, 06:44 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,888 Likes on 2,408 Posts
I can't see pix well on my phone
if u do chk camber make sure u chk toe too
excessive toe often produce very similar wear pattern as camber prob
Now if my comments makes no sense to ur pix above just ignore it. I can't see much other than ur finger on some dark stuff
Old 04-18-2008, 09:30 AM
sheep911
sheep911's Avatar
Originally Posted by Kevinlpl
No.
+1
Old 04-18-2008, 10:14 AM
997gt3north
997gt3north's Avatar
Originally Posted by sheep911
+1
+2
- this is why i have made numerous comments in previous posts that the front can handle "far more" negative camber and yet still outlast the rears (even if you only street drive)
- the reason i believe is the lever effect
- the rear tires being a 305 are a much larger lever and any negative camber will excessively wear the inside edge (as everyone has reported)
- since you want to run some rear negative camber for performance and to keep the rear end from passing you (i have found -2.2 in the rear to be a good compromise) you can then start playing with the front camber for added performance / turnin until you are just not happy with the streetability
- even with -2.8 to -3 in the front, the inside rears will still cord before the fronts and -2.8 in the front is still perfectly fine for daily driving
- for those that don't want the twitchiness just keep the front toe setting at zero to very slightly toe in
- with stock oe front tires (or the real mpsc 235/35/19s) the car will still slightly push even with -2.9 front camber but the center tire channels will wear slightly less than shown in the picture (but it will still wear some) - thus I believe if you are truly tracking your car (90% of the time) you are going to want your front camber in the range of -3.5 (and if you do this you are obviously going to have to increase the rear camber as well
paul
Old 04-23-2008, 02:20 AM
Kevinlpl
Kevinlpl's Avatar
My tires have 3880 miles currently front -1.6 camber 1/8 toe-in, rear -1.9 camber 3/16 toe in. Three track days. I will be going more aggressive on Camber.
By the way I don't do burn outs or donuts. I do a little drifting in some corners at the track.
Tire wear fronts. (New Nittos and HREs)
Attachment 272566
Attachment 272567
Attachment 272569
Rear Tire wear
Attachment 272568
Old 04-23-2008, 01:29 PM
Snowboarder54
Snowboarder54's Avatar
I really don't know how you guys get so many miles out of your MPSC's. Here are a couple pix of my last set of rears which only have 2441 miles on them. No track time only road. Alignment is as per street spec. I am changing them today as they are pretty much useless at this point.
Old 04-23-2008, 03:46 PM
Larry Cable
Larry Cable's Avatar
Received 3,641 Likes on 2,362 Posts
what pressures are people running their MPSC's at on the track; I ran them for the 1st time at Sears Point Monday and was amazed at how sensitive they are to pressure/temp, they seem very unhappy if they are not in their sweetspot.
Old 04-23-2008, 03:47 PM
Larry Cable
I also dont recommend spinning on them; I flatspotted one of my rears coming out of the carousel!
Old 04-23-2008, 04:53 PM
Kevinlpl
Kevinlpl's Avatar
Those sport Cups have alot of life left if you run them on the track! Street with water, well then I agree they could be dangerous, but I would love to have them for the track!
When I arrive in the paddock they are at 32-33. When they totally cool off in the morningthey are about 27. My goal is 34-36 in the hot pits right off the track. If you let them get too hot (over 36) they seem to get slippery...
Old 04-23-2008, 05:46 PM
Larry Cable
Yup ... I'd say 34 HOT was about the ceiling ... my rears were particularly unhappy and they seemed to be running > 34 hot....
Old 04-23-2008, 06:27 PM
mdrums
mdrums's Avatar
It is the toe that will wear out tires more than any negitive camber.
Kevinlpl, how are you liking the Nitto NT01's. I am think about these as my next track tire once my Toyo RA1's are wore out later this year.
Old 04-23-2008, 06:38 PM
mooty
mooty's Avatar
33f/35r hot
after driving to the track, i start at 26/26
now you know why i hate mpsc. they are great tires WHEN you are in their very narrow performance band.
Old 04-23-2008, 06:40 PM
mooty
mooty's Avatar
i said that many posts ago. no one seems to believe me.
Quick Reply: MPSC wear Q
