Porsche Coilover Group Buy......GMP Performance!!!
although ... I am making this up ... so I am probably emitting huge quanitities of bovine excrement
Youre right Larry but you would quickly have something like 2 times 10 factorial settings by adjusting the **** on the shock and the switch in the cockpit. PASM ON vs. PASM off times 10settings in front each one setting in the back-assuming you only want one setting in the back i.e. the right rear and the left rear are always the same. So approximately 2 (pasm off vs on) times 10 (front settings) times 10 (settings in the back)
Now I KNOW I am emitting Cow excrement!!
factorial excretia!
p.s
I would almost publically admit that I am tempted by this suspension if it were not for the fact that I know I would be humiliated by the teaming masses of other drivers that would ridicule such a choice when compared with Moton, K&W etc ... so I wont
I think what anyone considering these should find out is what are the stock OE spring rates front and rear and what are the Bilstein spring rates front and rear.
While a larger range of damping rates may? be useful, what would be far more useful for those serious about tracking is more spring rate and the damping to handle the spring
The above said, since the car can already handle a set of Hoosiers and if driven well be incredibly fast around a track on Hoosiers, changing out the stock suspension in this car would seem to be for those interested in running slicks - and if you are going this route, you could probably still get by if you remove all the rubber stuff first in the suspension - and at this point I think you are going to want a way better suspension than the one listed.
Having gone this route on other cars and having the experience (money spent), I would say go big or go home - motons/ohlins/etc + remove all the rubber or leave it alone.
GT3s already do this. The PSS10s seem like an adjustment to the stock 997 GT3 and not a radical change like it would be on a Carrera S.
If you really need to change the suspension on a GT3 it would be because you want to run slicks. And then you would need the fancy stuff like Moton or if you really want to feel like a baller Penskes. But if you run Penskes I suggest you have your own "shock guy" on the payroll.
Good question about the spring rates ... also I seem to recall (perhaps wrongly) that the 997 had progressive unlike the 996 which were linear I believe
