997 GT2/GT3 Forum 2005-2012
Porsche Coilover Group Buy......GMP Performance!!!
Old 04-15-2008, 01:44 PM
GMP - Matthew
GMP - Matthew's Avatar
Default Porsche Coilover Group Buy......GMP Performance!!!
Group Buy Has ended
Old 04-15-2008, 02:48 PM
Larry Cable
Larry Cable's Avatar
Received 3,602 Likes on 2,341 Posts
any tech literature on the PSS10's for the GT3?
Old 04-15-2008, 03:10 PM
GMP - Matthew
email me your questions and concerns and I would be glad to try and answer them for you. its easier to check my email than the forums when the phones are busy. thanks for your interested look forward to speaking with you
Old 04-15-2008, 11:26 PM
Larry Cable
I guess my general question is how do the bilstein's work with PASM ... do they in fact work with it at all or does it basically just fool the car into thinking that it's in normal/sport mode?
Old 04-16-2008, 12:50 PM
GMP - Matthew
You still retain your sport button to stiffen them up. Except with the bilsteins you adjust the height and when you hit the sport mode they stiffen up a lot more than the factory set up does and increases the handling tremendously in the corners and when the car is not in sport mode it drives like stock but a little bit firmer. I hope this helps. It doesn't fool it at all they completely work together just like your factory set up but they perform better than factory.
Old 04-16-2008, 07:06 PM
996toomey
996toomey's Avatar
I think his question is does the valving adjust within each setting sport / normal based on how the car is being driven.
The stock set up will adjust and the normal setting will firm up based on driving input or the sport might soften.
Old 04-17-2008, 10:12 AM
GMP - Matthew
Yes it does adjust by itself on the fly within each setting based on how your driving. Thanks for stepping in and making it clear what he was asking.
Old 04-17-2008, 01:28 PM
OldGuy
OldGuy's Avatar
I dont understand what the PSS10s get you in a GT3. They are PERFECT in a TT
or carrera or Boxster/Cayman which doesnt have adjustable suspension. They have
10 settings but in my TT I only used 2 settings 3/4 for street (front rear respectively)
and 1/2 front back for track. Once the hieght is set you are done. Like the GT3.
The sport and normal PASM settings give you 2 settings one for street one for track.
So I dont see what the PSS10s get you in the GT3. It gets you everything the GT3 has in
the TT Boxster or Carrera. WITH The PSS10s you should buy GT3 sways too. That give you the
full flexibility that the GT3 alreaady has.
Old 04-17-2008, 01:40 PM
GMP - Matthew
Can you adjust the ride heigh in the GT3 with factory suspension?
GMP - Matthew
I love that color by the way.
Old 04-17-2008, 02:49 PM
OldGuy
OldGuy's Avatar
Yes ride height is adjustable. the stock coil overs look like PSS9s and I should say I had
PSS9s on my TT not 10's. the PSS10s are a GREAT street track setup for a non adjustable suspension Porsche
Once set it takes literally 30 seconds to adjust. Maybe even quicker on the PSS10s as the adjustment
**** is easier to get to.
thanks on the Color. always wanted a SIlver 911!
Old 04-17-2008, 06:37 PM
Larry Cable
Actually I really had 2 questions:
1) do the PSS-10's have 2-setting PASM that is controlable by the car or not?
- the answer is yes
I guess my 2nd question is given that the PSS-10 is also "adjustable" presumably this adjusts the "normal" setting for PASM, so you can essentially
play with that baseline over and above the 2-settings from PASM?
So if you think "normal" is too soft/hard you can adjust the shocks accordingly to "set" "normal" to your tastes, then I guess "sport" is really incrementally determined by the adjustable "valve" within the PSS-1o that PASM adjusts
Old 04-17-2008, 06:47 PM
GMP - Matthew
You are correct that you have two settings to chose from and you can chose which every two settings you want them to be set at for stock mode (normal) and sport (stiffer mode)
Old 04-17-2008, 06:48 PM
Larry Cable
COOL!
Old 04-17-2008, 07:21 PM
OldGuy
OldGuy's Avatar
SO Matthew A GT3 owner would have 4 available settings instead of 2? That would be nice!
Quick Reply: Porsche Coilover Group Buy......GMP Performance!!!
