will thease tires fit 997 gt3?
hi guys,
getting ready for vir track event next mounth and going to buy a set of ccw's in 18'' size.i'm thinking about
mpsc's-- 265/35zr18 front
315/30zr18 rear
anybody do this setup?
thanks stuart
315/30zr18 rear
thanks stuart
- what I know so far would be this:
1) the inner part of the tire is going to be "very" close to the spring using a stock offset - I'm pretty certain it will rub the spring under load - with a few mm spacer or a slightly more outward offset you will be ok
2) using a stock offset, under load you will rub the fender - the fender will need "a little" baseball bat work
3) under full lock, you will very likely rub the fender liners - a little work by a shop to adjust the fender liners inward a little will fix this problem
so yes it is doable
but, i wouldn't show up for a trackday without first testing it as i'm 90% certain a little work is required
alternatively, just raising the ride height might also just work
Paul
GT3 player par excellence
315 fits for sure.
265 is very tight, IF it works.
255 will work
i run CCW 9 and 12"
255 will work
i run CCW 9 and 12"
oh yea, my car is lowered 6/10''
michlin does not make a 255 tire.
thats the size rims i was going to get 9'' and 12''.
255 fronts sets available than only in hooziers or toyo's
That is the tires I would love to run on my car. I have tried the 315 rear and 235 front and it was terrible. I am in talks with John at CCW. He has a set of these tires and a 997 Gt3. He is going to do some testing this Tuesday. I will call him wednesday and let you know what the outcome is. On the other hand Porsche gets the GT2 to turn with 325, 235. May be a different set up and a 235 could also work.
Stephan
Stephan
Stephan
Stephan
he has a set of c10's ready to go for me when he finnaly figures if this is going to work.
other wise its going to be the toyo r888 or ra1's 255/315 x18'' setup or the other is hoosier in 255/315,x18''
but what i really want to run is the mpsc's. 80 track and 20 street.
and as of today on tirerack site thease tires just came in.two mounths ago i was told to go with 18'' vs 19'' due to availbiaty.
but the other reason will be the cost 18 alot cheeper.
yea please let me know soon as you hear something.
thanks
stuart
I think the R6's in 245/35 and 315/30 are what I am going to try next. Not impressed at all with the MPSC's in the N spec 19" sizes for the track.
but R888 in 255 should be fine.
i dont remember the aspect ratios of the above two 255 tires.
Glad to hear they worked out.
Other than the obviously higher grip levels, how was the overall balance of the car (highspeed and low speed corners) with the new tires are rear bar
so as of rite now comfirmed best set up in 18'' are-----
255/315-toyos r888's
245/35 and 315/30 hoosiers
the problem with the mpcs's is that they do not make a 255 tire.
they only make a 235, and i'm told with a 235/315 set up you will get to much push.
so if a 265 doesn't fit (mpsc)than we can forget about this brand for a 997 gt3.unless fender work a spacers are used?
i also wanted to use this set of rims & tires 80 track and 20 street.so than this would elimiate the hoosiers.
maybe if the 265 mpsc's don't fit just get the hoosiers, and use this set just for dry track.and ues my stock 19's for back up and street.
are you waiting on the results also and if it works are going to buy thease sizes.
