997 GT2/GT3 Forum 2005-2012
Suspension upgrade
Old 11-25-2007, 01:42 PM
VB997
VB997's Avatar
...my suspension setup. JRZ three way motorsports with quick disconnects, RSR lower control arms all the way around, RSR toe links and GMG dogbones.
Old 11-25-2007, 01:49 PM
VB997
VB997's Avatar
...more
Old 11-25-2007, 02:02 PM
VB997
VB997's Avatar
...there has also been a lot of questions regarding the roof removal. Seen here during cage fabrication.
Old 11-25-2007, 04:42 PM
str8ner
str8ner's Avatar
John,
Looks great, Thanks very much for sharing these pictures with us. See you soon at the track,
Stephan
Old 11-25-2007, 05:33 PM
doc2s
doc2s's Avatar
Originally Posted by VB997
...they both work...the 40's will rub the front springs slightly if you run 2 degrees of camber or more when used with the 18" CCW C14's everyone is running.
thank you for the clarification.
Old 11-25-2007, 08:48 PM
TripleM
TripleM's Avatar
VB997
Just outta curiosity, what does the quick disconnect actually do ?
Old 11-25-2007, 09:36 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,660 Likes on 2,327 Posts
Originally Posted by TripleM
VB997
JRZ has remote reservoir. the quick disconnect allows you separate the cannister from the shocks so it's easier to fill/service.
Old 11-26-2007, 12:11 AM
TripleM
TripleM's Avatar
Thanks Mooty........
VB997
VB997's Avatar
AND
...it allows you to only drill a hole (or use a factory hole) the diameter of the disconnect (slightly larger then the hose) itself. Now you can place the canisters inside the car without having to drill a hole the diameter of the canister. Before quick disconnects you had to leave the canisters in the engine compartment or wheel well (where it gets very hot and is not easy to reach) or drill a very large hole to fit the canister through.
Old 11-26-2007, 03:33 PM
rmag
rmag's Avatar
Car's lookin' good John! Keep us updated with your winter projects.
Old 11-27-2007, 03:50 AM
HKE46Boy
HKE46Boy's Avatar
Amazing, anymore pics of the car?
Old 11-27-2007, 07:49 AM
VB997
VB997's Avatar
Thank you.
>>>>>>>>>>>>>>Stephan, I'm so sorry I've hijacked your thread.
The pics that follow are from three weeks ago. Something to point out is that this car was built *** backward. We had to do the full cage last so I drove it with a Das Sport bar until the cage fabricator could get to it.
Old 11-27-2007, 07:55 AM
VB997
VB997's Avatar
Some action shots...
Old 11-27-2007, 08:05 AM
VB997
VB997's Avatar
...last night. The cage should be done today or tomorrow...hopefully it will be in a paint both on Wednesday and then back on track at VIR (Chin event) next weekend!
Old 11-27-2007, 08:31 AM
George3
George3's Avatar
John
Awesome car. Where did you get the GT3 front grill inserts?
Did you install them yourself, or did a shop do that?
George
Quick Reply: Suspension upgrade
