Oil
Can anyone tell me what oil they are using to top up on the 997 GT3 ?
I need to top mine up and i have some Mobil 1 ow-40 SuperSyn which i used in my 997s and the manual says that i can use any approved oil .
Mobil 1 15/50
It's fine to add a pint of 0/40 M1, it won't change the grade and you'll be draining the thing pretty soon anyway.
Are you sure the car is down?
How many miles?
How many miles?
Originally Posted by Carrera GT
Mobil 1 15/50
How many miles?
How many miles?
450 miles , thats the thing ive done the oil test in my garage which is flat 6 times and its gone from full to the middle mark and the last one was at min. Going to wait till the morning and check it again .
Good. Definitely test again. I tested it once and got a little below the middle, then tested again and got the middle -- after about 1100 miles, so it basically hadn't "used" any oil since zero miles (testing at the same location.)
I'm still a bit confused about not having a dip stick to at least look at the bloody oil for Pete's sake ...
Right. It's now 5/50 ... I guess Mobil improved their multi-grade ability.
And the owner's manual uses 13F as the dividing line between bitterly cold climates and just plane ball-freezing weather.
About the only place I'd use a zero weight oil is the supercharger in the tow vehicle. Maybe if you drive in a very cold part of the country.
By the way, Porsche dealers with modern shops have their oils in "guns" (on lines hanging from the ceiling) so they don't have a wide range of options. I image they squirt 5/50 into everything. Perhaps for a "winterize" service they'd use bottled zero weight.
Just an FYI on a couple of facts
ALL Porsches worldwide are factory filled with 0W-40 this includes ones shipped to the Middle East where I imagine it gets pretty warm.
The factory race cars (SuperCup, RSR's and Spyders) run 0W-40
There is a slight horsepower advantage to running the lightest weight oil you can. F1 teams run an even lighter oil although it is a propriatary blend.
I run 0w-40 in both my street and track car.
Factory fill is 0W/40 and is the European extended change interval formulation, I only use Mobil 1 0W/40 in my tracked GT3 and it never uses a drop between changes every 12,000 kms and the car now has 51,000 kms. Most of the other Mobil 1 grades are not the extended oil change formulation.
