HT with PCCB Brakes, HOW!?
How do you heel toe with PCCB Brakes? I am probably just too used to the steel brakes, but I can not heel toe at all with PCCB because they engage so much faster.
Help.
At 613 miles and can not wait to go past 6k rpms.
Here is my rim after driving on sunset in Beverly hills the other night![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Greg
ps. I am going to renew my RL membership tomorrow. I didnt know it elapsed.
Help.
Greg
This has been my issue with pccbs. The pedal sits so high relative to the gas pedal and is so senstive, I went from having no problems in my M3 and steel braked 996s to WTF? in the 997S with PCCB.
So do I (heel and toe every day), but when I use the "ceramic" car, sometimes, at lower speeds, it is not possible because of low speed and pedal travel relationship. Really late, late braking (short hard stab) could possibly help, but that might bring it's own complications on the street.
Practice always helps for sure, but there are some situations where a "heel and toe" for the sake of a "heel and toe" is pointless; and that happens more (often) on the street in a ceramic equipped car than non-ceramic equipped car at low speeds!
I will have to practice with my foot at a different angle
Aside from rally drivers, I see very few pro drivers actually using their toe on the brake and their heel on the top of the accelerator. I have PCCBs on the car and I tend to roll my foot around the side of the pedal and use the side of my foot to match rpm to gear.
I went through a futile exercise of trying to "re-learn" heel-toe down-shifts in the more deliberate style of toe on the brake and heel on the accelerator pedal but I couldn't develop the flexibility in my ankle to make it work with anywhere near the same precision as rolling my foot.
Yeah, I was thinking an aftermarket gas pedal with spacers if need be to collapse the difference a bit.
But the PCCBs are so sensitive, it take more 'thought' than with any steel braked car.
Also, I find the PCCB pedal feel to be progressive and user-friendly -- perhaps they're not so good until they're bedded in.
The other thing is to practice on a Prius -- it has the panic brake assist thing where if you jab the pedal down to the engagement point, it thinks you're panic braking and releases stored boost assist and the brakes come up abruptly ... it takes a while to develop another "detent" in your leg to stop just before actuating the panic-assist but as close as possible to the engagement point. Plus, it's an electric system over the hydraulics, so the feel is about as informative as reading a book with your foot.
