RS single mass, aka light weight flywheel and ECU ignition programming
Wordsmith
I noticed in Excellence the factory applies a new ignition program for the RS given the change in characteristics with the 18lb reduction in rotating driveline mass with the single mass (aka "lightweight flywheel" aka LWF aka LWFW ...)
If you're going straight to the lightweight flywheel, see if your tech can get the RS update on their PIWIS ... : )
Wordsmith
Originally Posted by Flying Finn
I assume it's for stalling issues same way as in older 993s, I doubt it's a problem as is and if it is, new programming can cure it.
It isn't for stalling.. Stalling issues haven't been around since OBD2.. With the exception of clogged ICV's.. They are adjusting timing to maximize the benifits of the lightweight rotating assy. Now only if they installed the same rotating assy in the turbo motors..
Originally Posted by Philip in AL
You can use a Unichip piggyback unit to reprogram the ecu and take advantage of the lighter flywheel.
The Bosch Motronic unit can be reprogrammed, if required, its much simpler, less complicated and safer to do it that way. Of course it assumes that somebody can RTFM, and if they can't do that WTF are they doing mucking around with chips anyway?
R+C
