RS 3.89 R&P and 6th gear conversion..
#46
If the car is used for heavy track use, installing the 996Cup 3/4 shift fork is a good idea. I had that installed in my track gearboxes. The Cup shift fork is stronger as it's billet steel versus cast steel for the street part. About a $500 part available through Porsche Motorsport. If it's mainly a street car, I wouldn't worry about it.
Would also love your input on RS4.0 LWFW v. 7.1RS OE. From your other posts on this topic, I gather a minor - arguably imperceptible - improvement for a primarily street car ?
#47
@powdrhound - Brian and I have been exchanging messages on the re-gear. Can you offer your experience / insight on actually changing 2-5 / 6 vs. the R&P change alone? I am sending my 7.1RS box off next month to Rader for the re-gear and install of the Guard diff I bought but never installed on my .2.
Regarding the RS4.0 LWFW v. 7.1RS OE, the RS4.0/Cup (.81) flywheel is slightly lighter than the 7.1RS (.31) flywheel (9lbs v. 11lbs). Having a slightly lower MOI is beneficial as it makes the engine marginally more "lively". It's a very small difference but a worthwhile one in my opinion. Again, I wanted to have a correct all OEM 4.0RS drivetrain, gearbox and clutch wise. From a performance standpoint on a street car, it's basically a coin flip either way you go.. Hope that helps...
#48
Although re-gear of 2-6 while leaving the stock 3.44 RP can give you pretty much the same results as the RS 3.89/6th, I didn't consider this for the simple following reason. My 7.2 is pretty much all stock besides the 3.89/6th re-gear and the RS4.0 clutch. It's a low mileage car and never been tracked and as such I wanted to stick with an all OEM RS set up for reasons of originality from the standpoint of a full RS drivetrain set up. As such, I did not want to re-gear 2-6 leaving the 3.44 R/P as that is not a OE set up.
Brian Himmelman (02-14-2024)
#49
mikes70 (02-17-2024)
#50
Looking forward to seeing what you choose to do man. I am loving my stock 7.1 RS set-up w 4.0 clutch flywheel, but shifting it to the better ring/pinion and regear takes it up 2 notches. I have not wanted to spend the $'s for this.....yet. Living vicariously through your spend will likely make me jealous, and require my prying the wallet open. Go for it, force my hand please ![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Very useful to have @powdrhound 's views on it, but would similarly like to hear from you and Brian on whether it made a meaningful difference for you.
#51
My car came w the 4.0 setup, so I can't give you a comparison. I've always enjoyed the Lt Wt setup in all my cars. It makes a big difference over stock on lively Rev pickup. Very quick and useful, especially with the stock gear setup in our 7.1 RS cars. Rev matching is very easy. I'll have to ck the receipts for the work, but as I recall, it wasn't anything like the cost of what the regear and related transmission work will be. The chuntering alone is worth the price of admission (bag of nails) is an apt description. Sport purpose all the way. So your car is still on the dual mass setup?
#52
#53
Mine is not dual, as our cars came with LWFW. The difference between .1RS and 4.0 flywheel is ~2lbs, and the moment of inertia that @powdrhound explains. So 4.0 is even quicker. But is it $4k quicker . . . ?
jreifler (02-14-2024)
#54
I have the 3.89 R&P with 4.0 LWFW+ clutch on my 7.2 GT3. Big improvement. I keep the stock shorter 6th and like it. Gives extra oomph when passing cars on freeway speed without downshifting, the extra rpm never bothers me. But if the idea of a "complete OEM 3.8 RS gear box conversion" is your thing, go for the taller 6th.
#55
#56
Ah, OK, I guess I didn't realize the stock setup was Lt Wt. My 04 GT3's had dual mass, but that's probably a base GT3 only thing. Honestly don't know if I'd bother then. But since the previous owner spent the bucks, all good.
Checking the receipts, total job was $5,120 which included labor. He also dropped a Guard LSD in at the same time which added another $3,100, plus an additional $900 for specific labor for diff, Diff bearings and seals. Yikes!
#57
My plan is to 3.89 R/P, Turbo 6th gear, 4.0 FW/Clutch, motorsport clutches in diff. Unless im missing something for my .1 GT3
DD GT3 RD (02-15-2024)
#58
Still gathering data points, but arriving at:
1) 4.0 package is a game changer for any non-RS 7GT.
2) For RS cars, not dramatic, but still a slight improvement in both performance and durability.
3) If you need a new clutch on either platform, makes sense.
4) If electively just doing re-gear in RS with good clutch, prob not worth another $4k.
5) Proper diff is a game changer in any 7GT (which I knew from my .2).
And last point from chatting with Alex at SW earlier:
6) If your RS clutch is in good shape, can do just 4.0 FW and pressure plate and save ~ $2k.
#60
changster123 (02-15-2024)
