Coolant lines. Another question from 997RS newbie. Sorry.
My new to me 997.2 RS has 8700 miles, has not and will never see the track.
Should I get the coolant lines pinned? Do they have to take the engine out? 😬
I asked Isringhausen and they said it’s fine.
Most of the failures do happen as a result of DE. But there have been documented failures on the street from non tracked cars. Personally I’ve seen a friend in his 997.1 dump coolant and it wasn’t pretty. Absolutely no control. Line popped over his tire and his car instantly went spinning. Luckily he didn’t hit anything.
Most likely for putting around town you’ll be ok. But I would definitely not disregard it. Put a little money aside and one day just do it. It’s around a 5k job. Just search for other things to replace “while you’re in there” and you’ll have the piece of mind.
On the GT3, you can get to the coolant lines without taking the engine out. You can technically pin in the car. However, I'd highly recommend removing the engine. This way, you can actually remove the line from the fitting, clean it, re-epoxy it and then put it back in the car and pin. You can also take this opportunity to service any other easily accessed items (coolant expansion tank, hoses etc) while the engine is out.
Regarding when to pin. If driving on street only, you can wait. If it's a car show car, drive around town car, you probably don't need to worry about it as long as you don't mind the potential of having to flat bed your car one day.
If driving hard on the street, I'd feel more comfortable pinning now. You don't want to be mid-corner on a tight back road and have coolant on your rear tire and spin off the road.
I know you said no track, but for others reading. If driving on track, 100% pin. If not for you, then for everyone behind you on track.
Some fail at low miles, some at high miles.
Mine is a street driven car. Had mine pinned and installed the Dundon dampener at the same time. Motor does have to come out.
I had a coolant line failure on my 997 turbo I think around 10k miles. Was never tracked up to that point. Was fortunately parked at the time that I noticed a massive puddle of coolant on the ground. Mileage probably a factor in most cases but if it wants to sh*t the bed, it'll do it regardless.
Get the lines pinned, the car is expensive, the work is cheap.
I was once skeptical of pinning lines on street car, then I saw a low mile street driven car suffer coolant line failure.
I had mine welded for piece of mind. No track for her either. IMHO engine needs to come out. Do sharkwerks elbows at the same time. I also did guards lsd and dundon harmonic dampener at the same time. Those are not obviously must do's.
Congrats. Need
Pics. Lol
Congrats. Need
Pics. Lol
I think if you have failure on city streets, then you can address it.
Yes, it's a motor out fix, so perhaps address it if / when you get a new clutch (or upgrade to a 4.0L clutch kit)
I am on my 3rd GT car , this one a 2007 GT3 RS - it was owned by a Rennlist founder's wife as a track car, it has not had lines pinned/welded and I don't plan too either (unless I have an issue, or have an engine out service of some other sort).
Robocop305 (12-27-2020)
just don’t have the stomach to drop motor first thing.
What Tasman said. Dropping the engine is no big deal. Takes a good mechanic an hour or so to do it witht he right tools. I did the sharkwerks elbows, guards lsd, 4.0 clutch and dundon harmonic dampener. I also had all the plastic parts replaced and replaced the water pump as well IIRC. Been flawless for 2 years and 8k miles now including several track days. It gets driven more than my 991.2 3rs.
Congrats. Need
Pics. Lol
Congrats. Need
Pics. Lol
Originally Posted by ryantt
If one is running a stock clutch is there any benefit to doing the dundon harmonic dampener while the engine is out?
Originally Posted by Waxer
Tas: will be street driven. Babied too. Will wait for a service to do it.
