When to Replace Failure Prone Coolant Lines - 997.2RS
Originally Posted by TRAKCAR
If you go to the track before pinning, at least run water wetter.
My worry now is if they blow while idling at Starbucks
Originally Posted by cajerseyboy
What month and year was your car produced? Mine was fairly late 2011 model year. Any indication that this issue was known to Porsche and they fixed it in the late production runs?
Mine are the same
Latte bitches need all the grip there is on offer at the drive through.
Do it ASAP whether you track or not imo. Friend bought a 15k mike 7.1 gt3. 1st track day out at Laguna coolant pipes let go. Going into turn 2 he was on my rear the next thing I see in my rear view is smoke and him spinning.
another friend bought a 20k mike example and 2nd day of ownership the pipes let go on the highway.
Update fellas - Moving forward with pinning the lines w Sharkwerks. While the engine is out I'm taking care of a 'few' more items while it sits in the hands of the experts.
- Sharkwerks Coolant pipes
- Guards LSD - Internal components quoted but I am seriously considering getting the upgraded mooty billet housing to go along with it.
- BMC Air Filters
- Oil change
- 4.0 RS Clutch kit w Flywheel
- RSS adjustable toe steer kit
- RSS adjustable rear link kit
Will ask about adding in these additional items:
Front and rear main seals
Replace Rubber hoses
Coolant expansion tank
Variocam bolts
Water pump
Replace spark plugs
Already have EVO Tune and Function first shift right solution installed. https://www.sharkwerks.com/transmiss...-987-2-FUNT476
Anything I'm missing? The next time I have the engine dropped it will be for the 4.1 surgery so want to make the most of this procedure.
- BMC Air Filters
- Oil change
Variocam bolts
Water pump
Replace spark plugs
- BMC Air Filters
- Oil change
Variocam bolts
Water pump
Replace spark plugs
- BMC Air Filters
- Oil change
Variocam bolts
Water pump
Replace spark plugs
Originally Posted by bonehead
As mentioned above, I'd consider the harmonic dampener as well.
The bolts backing out is the one catastrophic failure that I worry about (perhaps unnecessarily) that could be averted by wiring the bolts and installing the dampener. If/when it's time to pull my motor, I'm going to do it.
I put the harmonic dampener in last year when I pulled the motor to pin it. So far so good!
Quit Smokin'
Because if the data supplied by neil harvey is correct, the damper solves the cause of the problems, rather than addressing the symptoms. I've seen cracked off alternator mounts, and it's not unreasonable to believe that engine harmonics are related to the resonance flap screws backing out. I also wonder if the engine harmonics have something to do with the way the coolant fittings come apart over time. If the engine really does have harmonic issues, its better for all to components to solve the root cause rather than bolting everything down with bigger bolts.
http://performancedevelopments.com/p...enginefailure/
My question is does this happen in the 997.2 RS that has a stock SMFW?
The following 2 users liked this post by cajerseyboy:
Auto_Werks 3.6 (09-27-2019),
TYPE911 (11-11-2019)
Thanks for the name drop. I looked up Neil Harvey and he wrote a very detailed piece on this topic here if anyone is interested in some light, engine dynamics, reading.
