CCW 997 GT3 NB Offset
Does anyone know what the standard offset is for CCW C10 or C14 track wheels for 997 GT3 NB (non RS)? 18x9 and 18x12 widths. I ran 245/645/18 and 315/680/18 Pirelli DH on the CCW's.
I'm trying to find a replacement set and can't find the offset stamped anywhere on the wheels.
Has anyone used OZ Challenge wheels on a 997.1 GT3 NB?
The offset seems to be lower than the Alleggerita which I know works.
https://www.tirerack.com/wheels/Whee...tandard+Brakes
997.1 gt3 wheel offset nb
Stock wheels for the 997.1 nb are
8.5x19 et 53
12x 19 et 68 rear wheels have the 5 mm spacers making effective offset 63. Don't think the fronts do.
8.5x19 et 53
They're CCW's so I'll need to measure the backspace and convert from there. I want to say they're 50mm but I need to double check.
-Dino
-Dino
I think 50 front and around 68 rear should be about right. I just ordered a set of OZ Challenge 18x8.5 ET50 and 18x12 ET63 (I won't run the factory spacer). Hope they fit.
I know this is an old thread but thought I'd add to it for those like me searching for more detail.
I have a few sets of CCW C14 and was measuring them up tonight. Here's what I found.
Front 1 (9x18)
Backspacing 175mm
Total Width (lip to lip) 255mm
Front lip to mount face 80mm
Offset (calculated) 48mm
Front 2 (9x18)
Backspacing 180mm
Front lip to mount face 75mm
Offset (calculated) 53mm
Rear 1 (12x18)
Backspacing 235mm
Total Width (lip to lip) 330mm
Front lip to mount face 95mm
Offset (calculated) 70mm
Rear 2 (12x18)
Backspacing 230mm
Front lip to mount face 100mm
Offset (calculated) 65mm
Give or take a couple mm as I was just trying to get ballpark #s. With these #s I could go to CCW and get exact details.
Front 1 (9x18)
Backspacing 175mm
Front 2 (9x18)
Backspacing 180mm
Rear 1 (12x18)
Backspacing 235mm
Rear 2 (12x18)
Backspacing 230mm
