997 GT2/GT3 Forum 2005-2012
Cup electric PS pump conversion
Old 10-17-2017, 10:42 AM
JarmoL
JarmoL's Avatar
Do these electric pumps make a lot of noise? Can you hear it while driving on street?
Looks very tidy mounted beside the battery!
Old 10-17-2017, 10:50 AM
CRex
CRex's Avatar
It's a good way to reduce parasitic power loss on your engine belt... how are you powering this pump though? In the cup this pump drew so much current that I think it has its own fuse...
Old 10-17-2017, 03:05 PM
T10Chris
T10Chris's Avatar
Perfect timing... I'm doing this mod as well. I've got the pump as well as the Rebel fittings for the PS rack.
I've been trying to come up with a good mounting solution myself. Interested in seeing how yours goes
Old 10-17-2017, 03:35 PM
bmwtye
bmwtye's Avatar
It has an inline 80amp fuse so you wire it directly to the battery.
Old 10-17-2017, 04:52 PM
ngng
ngng's Avatar
it sounds like a jet engine
Old 10-17-2017, 05:06 PM
bmwtye
bmwtye's Avatar
Old 10-18-2017, 01:22 AM
JarmoL
JarmoL's Avatar
Thanks! That is some noise then..
Old 10-18-2017, 03:53 PM
pete95zhn
Former Vendor
pete95zhn's Avatar
Good info, thanks! Makes me think about future mods.
​​​How about belt length and rollers required after PS pump removal?
Old 10-18-2017, 05:37 PM
Scott.
Scott.'s Avatar
Since you also have a 996 and close by, here's my custom Rothsport mount for the electric PS. I'm sure they could make more if you convince Jeff.
Old 10-18-2017, 07:38 PM
Tom@TPC Racing
Premium Sponsor
Tom@TPC Racing's Avatar
OP,
Nice job on the modeling of the bracket.
Just for reference, I got a set of the Rebel brand aluminum fittings on ebay, the measurements are spot on. Pretty legit for under 100 bucks!
Low pressure fitting.
High pressure fitting.
The only functional difference is on the high pressure fitting the OEM/Cup version has a built in screen. The screen won't change the performance. Should the pump fails and break into pieces the screen will protect the rack to some degree but its pretty unlikely that'll happen so I don't having the screen is critical. One could install an inline filter if so desires, but again I don't think its necessary. If I had to do my car again I wouldn't hesitate to use these fittings. I would get new OEM sealing rings though.
I am sure the HRG brand measures equally well given their reputation.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
Darkstar1 (09-02-2023)
Old 10-18-2017, 07:51 PM
bmwtye
bmwtye's Avatar
Other pertinent part numbers in relation if your pump didn't come complete:
997.314.090.9A - Cap and overflow tube. (#16)
996.314.759.9B - Rubber Disk. (#4)
999.703.269.01 - Silent Block 25x15/M 6 (#3)
999.073.259.09 - Screw m6x8. (#2)
Old 10-18-2017, 08:50 PM
ngng
ngng's Avatar
Originally Posted by Tom-TPC Racing
OP,
Just for reference, I got a set of the Rebel Racing brand aluminum fittings on ebay, the measurements are spot on. Totally legit for under 100 bucks!
I've got a set of HRG coming as well, I will take measurements but I'm sure they're fine. I paid $90 to HRG and he included O rings and shipping! I will likely model a set myself and machine it out of 6061.
It's pretty cool we can use these fittings and bypass the Cup lines entirely!
Tom- do you have any thoughts on the Cup idler pulley with a bracket vs just replacing the belt with something smaller?
Old 10-18-2017, 08:54 PM
ngng
ngng's Avatar
I don't have the cap with overflow. Necessary? Or is it gonna **** all over my floor?
Old 10-18-2017, 09:02 PM
ngng
ngng's Avatar
so I'm seeing lots of round bases that hold the PS unit. is this really necessary? the 3 posts that hold the PS pump should be enough, no?
Old 10-19-2017, 02:37 AM
ngng
ngng's Avatar
started modeling the fitting based off of -6 fitting and the measurements tom provided. will double check with a caliper and mic once they arrive
Quick Reply: Cup electric PS pump conversion
