Wheel fitment question 2010 GT3RS
Gent's,
I am sure you have seen these wheels for sale. I am in need of assurance this fitment will work on my GT3RS. Thoughts on them clearing PCCB's? They did on a standard GT3 w/PCCB's. Thanks in advance..
This is a set of Finspeed 18" wheels. These are very high quality light weight forged 6061 aluminum wheels, Over $4000 new. This set is the F14 style, center lock, with Knurled bead seat option. They are the Gun Metal color. They have clearance to accommodate large brake calipers. The fronts are 18" x 9" with 49.5 offset and the rears are 18 X 12 with 63mm offset. I weighed these on my bathroom scale and fronts weight 20.5 Lbs rear weight 23.5 Lbs.
Removed from and perfect fitment on 2010-11 997.2 GT3 with clearance for PCCB calipers. Should fit other Porsches as well
Very Good Condition. Decided to go different direction with my project.
shipping in CONUS $200. local pick up ok.
no problem. the PCCB on the 997.2GT cars is same sizing/caliper as the non PCCB. It'll be fine. Only the 997.1 non PCCB (iron) had smaller front rotors.
Thank you both. I appreciate it...
CRAP! I was focused on the PCCB clearance.
Narrow body wheels DO NOT fit the wide body cars in the rear correctly you'll need about a 20mm spacer.
GT3 player par excellence
it will clear pccb but it will not work on RS.
a_Y: for 18" you can go with offset i had. for 19" i suggest OEM offset.
anything else is just disaster waiting to happen
