rear brakes - please help >>
replacing rotors and pads today. i just finished the fronts, but have no idea how the rear caliper comes off. i've removed the carrier bolts, but it's stuck. what am i missing?
ebrake was off. the pads were just compressed on the rotor very hard. is there a decent write-up on the rear brakes on the 997.1 GT3? I did the job today, but i feel like it could have gone smoother.
997 should be easy.
But, before you start, check reservoir, open cap, spread pads using this tool
check reservoir.
while pads in place, squeeze caliper piston all the way in.
Remove bolts and calipers
Remove pads
remove rotors.
Make sure you check reservoir after each change out, may need to drain.
check reservoir.
Remove pads
remove rotors.
one question - i don't see how i can use that tool with the caliper in place. do you mean, remove the caliper and then with the pads in place, use the spreader tool?
I just use and adjustable plier wrench to push the pistons in, or my hands. I don't see how the tool above would work, you would need one of the special 4 piston spreaders to get inbetween to push the pistons in.
