View Poll Results: Has your PDK gearbox needed replacement? Please don't answer if your car is a manual.
Yes
21
11.17%
No
167
88.83%
Voters: 188. You may not vote on this poll
Is PDK the new IMS?
#46
I'll verify that these cars are highly sensitive to batteries. The AC on one of my 993's once cut out and my Indy was stumped. Went to the dealer and they replaced the battery and problem solved. The car started fine and I had no reasons to suspect an issue with the battery. Go figure.
#47
Let me add this from a 997.2S DD
Aside from the old, tired "manual is more involving, and besides I'm a better, slimmer, handsomer, richer driver while rowing my own gears" argument, let me add that we bought our 997.2S PDK in March of 2014, and she is about to roll over 82,000 miles in daily traffic and club events with absolutely no issues.
To be honest, I know that some of you PDK haters are looking to start some sort of issue with this transmission. A schadenfreude of sorts. But I can tell you that those that hate it have never driven one. Almost everyone to a T that drives a PDK comes away impressed. It doesn't have to be a "leave it in D" transmission. Put it in manual and row away. No overrides. You are the boss.
Anyway I just wanted to chime in and let you know that at 82K miles I haven't seen any issues with the PDK. I WILL add though that a low or bad battery WILL cause havoc in a lot of other areas. But that isn't the tranny. And shops WILL take advantage if they can't diagnose something. Because it could NEVER be the battery!
RLH
Currently:
09 997.2S PDK
84 911 Carrera 3.2 Targa
87 928S4 Auto
88 944 Turbo S Plaidmeister
Past:
'73 911T
'82 911SC
'95 993
'06 997.1S
RLH
Currently:
09 997.2S PDK
87 928S4 Auto
Past:
'73 911T
'82 911SC
'95 993
'06 997.1S
#48
Mine failed mid-2015 with 47k miles.
2009 C4S, daily driver with ~8 track days / year
It started with a check engine light for "O2 server malfunction" and then a couple hours later I got "Transmission emergency run" fault and the car was stuck in 2nd gear
replacement costs: parts $8.5k, labor $2.2k
Hi Hatzenbach
Mine is 2010 C2 with 33k miles, it stuck in 2nd gear twice and functioned normally after pulling over and restart the engine. It first happened 3 months ago, the dash showed white transmission emergent run twice previously. I then have mine checked at local dealer. After 1 day of exam, the mechanic can't find anything wrong and he reset the PDK computer (?). However, It happened again yesterday. And again, after pull over, shut down, rest a while, then restart. The car act as nothing has happened. I am curios what happened after your car stuck in 2nd gear before the transmission is replaced. Was it like mine can go without problem after restart or just stuck there?
Hi Hatzenbach
#49
#50
Ummmm do you think time has anything to do with it? ..give PDK another 3-5-10 years of blowing up and more with Porsche offering NO good will in a few more years on 09-10 cars and your one page will be 5 pages soon enough.... 07-08 cars have less IMS risk then early 09-10 have PDK risk that's for sure.
If I ever end up in a 997.2 it will be a 6sp.... avoiding a 997.1 due to possible IMS but picking up a 997.2 pdk is foolishness.... buy it cause it has a better designed PCM, has some more hp, or get the 6sp if your a worry wart etc. But to avoid one risk to get yourself
into another is bass ackwards way of logic.
or just buy what you like and can afford people and enjoy it....
your heart could explode tomorrow before your IMS or ur PDK....
Now with all that said, if my PDK transmission on my "new to me" 997 with only 31,500 kms (or 19,500 miles) was to crap out on me, I hope it happens before April of 2019 because the car is still under warranty until that time. haha
#51
With PDK, I believe pulling both paddles toward you at the same time selects neutral, which would be the equivalent of pushing in the clutch in a manual transmission car, but since I don't own any PDK Porsches, someone else should verify that's how you select Neutral.
#52
In a rear engine car, with the weight pendulum back there, if you feel the rear end stepping out, pushing in the clutch to cut the power, which shifts the weight balance even more toward the front, unweighting the rear even further, is the last thing you should be doing. It's counter intuitive to your reflex, but what you want to do is maintain or add throttle to keep the rear weight how it is even add a little, then countersteer into the skid, with will put you into a nice gentle rear end drift and allow you to power through the corner. If you've never done this in a 911, you're missing half the fun.
#53
Like I have mentioned previously, my experience is if you keep the gearbox cool and service the pdk side much more often than Porsche tells you, they are very reliable. I've seen cars with hundreds of hours of track only use have zero PDK issues, but we have always added extra cooling and change the fluid after every other event and filter ever other fluid change. May be overkill, but it works.
On all my cars I own with DSG boxes on the street, I will change the fluid every 2 years or 24,000 miles TOPS.
It's been my experience that even on full autos, I can tell when the fluid it getting to about 20k miles. Shifts usually aren't as crisp.
If you wait to change the fluid until you hit 100k miles, the transmission will likely fail after changing the fluid the first time. I've had that happen personally on more than one car with unknown service histories and we're pretty sure had never had their transmissions serviced.
#55
But it's not supported on the 997.2
Karl.
#56
This should be entertaining...
#57
Received 2,010 Likes
32K miles on my Turbo S PDK. 3 owner with records from new. Now sure how they drove it but I drive it mostly conservative unless I'm in the mountains, but even then the tranny isn't being abused simply due to having to hold only two or maybe three gears at those speeds. Not a ton of shifting.
32K miles...Should I proactively have my PDK serviced?
#58
I would. The maintenance schedule is 60k miles or 6 years for the first PDK service. My 2011 was also under the mileage but I noticed a big improvement in shift quality after the PDK service. "YMMV".
https://gaudinporschelv.com/images/d...9_911S_997.pdf
#59
Good deal...Thank you!!
#60
FWIW.....to those who have had more than one " Transmission Emergency Run " event, it may or may not mean anything. The failure of the PDK on my -09 C4S was preceded by two of those events. Just the warning on the dash but no other problems. Both cleared themselves by turning the car off and back on. Third time the same warning came on the car just wouldn't move no matter which gear was selected or in which mode. Flatbed to the dealer where it didn't take long to determine the whole unit had to be replaced. Codes they pulled indicated some kind of software failure.
Best I can remember these three events happened within a 1-2 month period.
