Help: exhaust tips alignment issue
From my experience, they can be moved around a fair amount and they will stay where you put them as you tighten the bolts. There is more to this than just having them "look the same" on either side. From what I see, neither side is as high as it should be. There are pics and specs for position in the openings in the workshop manual that was posted here in the last few months. Still can't lay hands on it. Measured mine and the outside pipe should be vertically 15 mm from the inside of the black trim piece in the bumper. Laying a straight edge on the beveled end, the tips should just about be even with the top of the black trim. Hope that helps.
They actually both look a little low, so I'm on the mounts bandwagon. If it's an equal on both sides look you're concerned about, you could adjust the passenger side best you can for levelness and alignment, then adjust the driver's side a bit lower to match.
The RSS mounts are great though and help to tame that heavy pendulum swinging around the back (engine). They do create a slight bit of NVH or resonance around 3,000 RPM but the trade-off is worth it and after the first few drives you won't notice it again.
thank you all for the valuable input. I am the 2nd owner, car has 45k miles. Today i took the bumper off and inspected. Everything looks ok. So if its sagging (evenly on both sides) it could be the mounts.
Just an update, I measured the tips on both sides as per the below Porsche service manual diagram
The X number for me is 27mm and Y is 30 mm on each side. Left and right sides are almost the same give or take 2mm.
Z is about 25mm
If its the mounts it would mean the mounts are sagging exactly the same on each side
Z is about 25mm
There is play on the hangar bolts, and the centre muffler or x over pipes if there has been any mods. Your z is out by 10- 12 mm. You need better pictures for any help.
Mine looks tucked in exactly like that on the same side, except with the Carrera 2 tips - which led me to your post. Not sure how long it's been that way or what made me notice it, but yep - just like that. No sign of scrapes or any indication that I backed into something (and forgot about it) or that someone else bumped into me in a parking lot - seems too low for that anyway. They both are level and even from the ground - I'll check the service dimensions later.
I reckon I'll try to adjust it or get my service guy to look at it next time I'm there.
As you can see from the pics attached, the passenger side exhaust tip is not straight.
I have seen the threads with motor mounts as suspect but the passenger side one is not hanging lower than driver side. its more of a horizontal alignment issue.
I have not yet taken the bumper off to check the muffler hangars/bolts.
Car has the PSE
any suggestions?
top view, passenger side seems off
Car has the PSE
any suggestions?
