Low compression in #6 (new guy post)
Old 06-21-2017, 01:08 AM
  #46
user 72902
user 72902's Avatar
Originally Posted by 4Driver4
And you went 4.0?
i have a 3.8
Old 06-21-2017, 12:38 PM
  #47
earossi
earossi's Avatar
Default Wrist Pin Intall Tools
Thanks for the nudge. Here's the latest.
After taking the case and pistons to the machine shop and chatting with a few local Porsche engine shops, we are pretty comfortable in a stuck ring diagnosis. There was some sludgy build up in the grooves of several pistons, and no other issues were found. We are going for a full rebuild with Nickies. The case is at the machine shop now, and we will be doing the reassembly once it comes back. I'm hoping to find a reasonably priced wrist pin and clip installation tool, but have not had any luck as of yet.
The heads have been checked and cleaned by the machine shop, and have passed muster with no issues.
Oh, and we are going 4.0 on the rebuild.
Suggest that you contact Stomski Racing. They have come up with a wide array of custom tools for 911 engines. Not sure what the configuration or diameter is for your wrist pin retainer rings, but Stomski has at least (2) sizes of tool that allow for easy installation of the retaining rings. Would have been a PITA to install the wrist pin snap rings on my 993 engine if I had not had the Stomski tool which was about $75. Call and talk to Steve Stomski. Nice guy.
Old 06-21-2017, 04:25 PM
  #48
AWDGuy
AWDGuy's Avatar
Originally Posted by jkw911
Interesting. When Jake did my rebuild he installed new OEM rods which were part of the package.
I would imagine he wants everything new as possible in there. I built my motor in my garage though and went with the recommendations made by LNE and my budget.
Old 06-21-2017, 04:29 PM
  #49
AWDGuy
AWDGuy's Avatar
you can find the wrist Clip insertion tool on ebay for under $250, that's what I used.
Old 06-21-2017, 04:56 PM
  #50
Lvt19672
Lvt19672's Avatar
i have a 3.8
How come you didn't go 4.0?
Old 06-21-2017, 05:52 PM
  #51
user 72902
user 72902's Avatar
I really admire that because I've done enough work on my p-cars to know how complex that project is. Considered doing it myself but only briefly. Well done!
Old 06-21-2017, 05:53 PM
  #52
user 72902
user 72902's Avatar
I checked virtually every extra box and had to draw the line somewhere. 🤑
Old 06-21-2017, 08:04 PM
  #53
sober_owl
sober_owl's Avatar
On the m96/96 3.6 from my understanding its same stroke so to go to 4.0 you just switch to bigger piston bores!
Also why go nikies vs iron sleeves? Bisimoto is running them on his 1000hp porsche with an m96..
Ive been looking into this for the future in case my 3.6 ever takes a dump!!
Old 06-22-2017, 07:50 AM
  #54
4Driver4
4Driver4's Avatar
Thanks for the tips on the tools. I may have a source to borrow them, but obviously the wrist pin install is the biggest challenge.
Old 06-22-2017, 09:25 AM
  #55
AWDGuy
AWDGuy's Avatar
If you take your time and do your measurements right (and use good tools), you can do it with a lot of confidence. I forgot important dowels in the block, so i had to do it twice.
Old 06-22-2017, 09:31 AM
  #56
Petza914
Petza914's Avatar
Received 6,188 Likes on 3,945 Posts
Check into the line of "Faultless" tools developed by Jake and Charles. Also, snip the little pigtail off of the wrist pin clip so you don't have to try and get it into the hole - this is how Jake taught us to do it at his M96/M97 102 engine class.
Old 06-22-2017, 09:36 AM
  #57
AWDGuy
AWDGuy's Avatar
those tools are $1500+. The $200 ebay ones did the trick for me and I'm not remotely close to being a pro at this.
Old 06-22-2017, 09:33 PM
  #58
sober_owl
sober_owl's Avatar
For you guys that have done this yourself.. do you have a service manual? Ive been looking for a hard copy but only found up to 996 the 997 theres pdfs online but not the same..
Also jake was supose to come out with an m96 engine rebuild book but i think it never happen..
Old 06-22-2017, 10:03 PM
  #59
Petza914
Petza914's Avatar
He has a torque specs book that you can buy from his Knowledge Gruppe site and he has his engine e building course attendees buy the class book, but I don't think he sells that separately and it's copyrighted.
Old 06-23-2017, 12:32 AM
  #60
sober_owl
sober_owl's Avatar
Usualy service manuals have all the torque specs and lil tricks to rebuild an engine.. i rather buy a comple book for the car not just the engine.
Quick Reply: Low compression in #6 (new guy post)
