PSE Button
Old Feb 3, 2017 | 01:32 PM
jfintexas's Avatar
jfintexas
Default PSE Button
I just bought an 06 C4S with a number of options including PSE (Option Code XLF). On my 04 C4S, also with PSE, I had a button on the dash to turn it on/off. No button on the 06. Is that common for PSE from factory? I actually prefer it on full-time, but was just curious about the button.
If relevant, I do have the Sport Chrono Package Plus as well (Option 640).
Thanks!
Old Feb 3, 2017 | 03:58 PM
jhbrennan's Avatar
jhbrennan
PSE from the factory should have a dash button - the graphic on the button looks like the two tailpipes. I had an 06 C4S with those options (XLF and 640) and did have the PSE button.
Old Feb 3, 2017 | 04:13 PM
jfintexas's Avatar
jfintexas
I though so, too. It would be down with the suspension, sport, and PASM buttons. Here's a pic of the dash. No button, but I ran a VIN check and checked the options list that came with the vehicle. Definitely indicates Sports Exhaust.
Old Feb 3, 2017 | 05:21 PM
nwGTS's Avatar
nwGTS
Unplug and zip tie the PSE plug. 997.1 location:
https://rennlist.com/forums/997-foru...-question.html
Also, make sure you actually have PSE unlike the idiot in the link.
Old Feb 3, 2017 | 05:27 PM
bmwfan328's Avatar
bmwfan328
Do you have the X-51 package from the factory? My 06 C4S X-51 doesn't have the separate exhaust button. Valves are only open in sport mode.
Old Feb 3, 2017 | 05:29 PM
Derek Zoolander's Avatar
Derek Zoolander
Since you have Sport Chrono Package Plus and PSE, your PSE is controlled by the Sport button. As nwGTS said, unplug the PSE electrical connector and zip-tie it so your valves are always open.
Old Feb 3, 2017 | 05:31 PM
jhbrennan's Avatar
jhbrennan
Maybe true but I had the same option config as OP on my 2006 C4S with the PSE button.
Old Feb 3, 2017 | 05:32 PM
Derek Zoolander
I have the same SCP+ and PSE and do not have the PSE button.
Old Feb 3, 2017 | 05:44 PM
jfintexas's Avatar
jfintexas
I've tried it with and without the Sport button pressed. Sounds exactly the same. PO may have done this mod.
Old Feb 3, 2017 | 05:45 PM
jfintexas's Avatar
jfintexas
LOL. Hearing different experiences from the factory. I guess the button was an option based on what direction the wind was blowing :-)
Old Feb 3, 2017 | 05:56 PM
Derek Zoolander
FWIW, this is the first time I've heard of someone having Sport Chrono + PSE and having a PSE button..
@jhbrennan, I'd run your VIN to make sure your car has factory PSE
Old Feb 3, 2017 | 06:27 PM
porscheralph's Avatar
porscheralph
I have Sport Chrono +PSE and HAVE a PSE button. Now there are at least two of us.
Old Feb 3, 2017 | 06:47 PM
jhbrennan's Avatar
jhbrennan
Well you're making me doubt my memory now. I'd run out and check but I sold the car 6 years ago but I checked the VIN again and as you can see it had the two options. Don't know if the Launch Edition option made any difference. I remember when I first took a test drive in the car, salesman made a point of showing me the PSE button. I guess it's a moot point if OP has PSE rigged for FT operation.
File Type: pdf
Old Feb 3, 2017 | 07:53 PM
jfintexas's Avatar
jfintexas
Okay, I've officially ruled our idiocracy :-) Different pipe sizes and orange connector, clearly visible. But, I offer that my PSE seems to be on all the time. I went for a hour drive just now, up and down all the gears with sport on and off, sunroof open and closed, and absolutely no discernible sound difference. Puzzling indeed...
Old Feb 3, 2017 | 08:36 PM
jhbrennan's Avatar
jhbrennan
IIRC you can enable PSE on all the time by disconnecting a vacuum line and leave the orange plug in place. Maybe that was done by previous owner.
