Brake rotor rust
Old 01-02-2017, 03:02 PM
user 72902
user 72902's Avatar
Rust is not an issue for me and there has been enough feedback on Hawk Performance Ceramic pads that I'm comfortable with their performance.
Old 01-02-2017, 05:50 PM
platinum997
platinum997's Avatar
Good info guys..
I will try some hydes rust stopper. Only an issue for the winter months. Sounds like it's not a big deal and will come off on next drive anyway.
Old 01-02-2017, 05:57 PM
cosm3os
cosm3os's Avatar
Originally Posted by STG
Who gives a rats ***??
It's not your car and nobody is asking you to do anything. He has a question/concern, other people chime in. You don't like? Ignore.
You suggest sanding the rotors?? Really
Sarcasm. But is it any sillier than worrying about surface oxidation on a rotor, or spending time spraying them when you can drive to the end of your driveway?
Old 01-02-2017, 06:32 PM
Mumbles
Mumbles's Avatar
Originally Posted by platinum997
Good info guys..
Its normal for the rust to occur with moisture in the air. Just a few revolutions of the wheels with the brakes applied removes all.
Old 01-03-2017, 12:41 AM
Edgy01
Poseur
Edgy01's Avatar
Next time, order PCCBs on your Porsche. 103,000 miles and not a spec of rust--and neither on the hats, either, which are aluminum.
Old 01-03-2017, 01:20 AM
Petza914
Petza914's Avatar
Received 6,601 Likes on 4,197 Posts
+1 on the PCCB brakes. Liked them so much on my 997, I'm retrofitting them to my Cayenne. No dust, no rust after washing, incredible braking performance without any fade, and rotors with proper care and pad replacement at 50% wear will last the life of the car if street driven.
With iron rotors, the rust isn't really a problem, but the first drive that scrapes it off, deposits all the rust dust on the inner barrel of the wheel, which then requires another quick cleaning.
I'd be careful about spraying anything on your rotors. Sounds like that product is designed for it, but I personally don't want anything coming between the pad material and the rotor surface since what makes the brakes stop well is bedding the pad material into the rotor so you have effectively pad material to pad material contact when stopping. Introducing a foreign material to that equation just doesn't seem like the best idea to me.
Old 01-03-2017, 01:34 AM
Gonzo911
Rat Balls
Gonzo911's Avatar
Sometimes, when my car sits in the garage for a day or two, it gets dusty. Any ideas?
Old 01-03-2017, 02:15 AM
Petza914
Petza914's Avatar
I have some stuff you can spray on.
Old 01-03-2017, 02:48 AM
Iceter
Iceter's Avatar
Nobody's panties are in a wad over this but you. Lighten up, Francis.
And sanding the rotors is no less ridiculous than spraying them with some rust inhibitor every time you park the car. Is he supposed to put the car on a lift and spray the backsides of the rotors as well? Because they rust, too.
If the car just sits still and looks pretty, I'd recommend Cosmolene.
Old 01-03-2017, 06:32 AM
user 72902
user 72902's Avatar
You will reduce brake dust and reduce your unsprung weight by converting to PCCB's but you will not increase your breaking performance.
Old 01-03-2017, 06:50 AM
platinum997
Gonzo...appreciate the input. Sorry if the question isn't up to your standards.
I figured it was a common concern given how many of us park the cars for the winter.
Old 01-03-2017, 08:34 AM
wc11
wc11's Avatar
While I don't stress it, what I don't understand is why they rust in the 1st place (dumb question I know) as my and I'm sure pretty much everybody elses daily driver doesn't rust.
What's so different about their discs?
Old 01-03-2017, 09:09 AM
Mumbles
Mumbles's Avatar
I do believe that the steel is cast so its prone to surface rusting
Old 01-04-2017, 06:59 PM
Gonzo911
Rat Balls
Gonzo911's Avatar
I actually have very low standards...
Old 01-04-2017, 08:05 PM
Lvt19672
Lvt19672's Avatar
Red face
Does anyone bother using the search function anymore?
Quick Reply: Brake rotor rust
