Brake rotor rust
Brake rotor rust
Car has been sitting almost 20 days or so and starting to notice rust on the rotors.
What can I put on them to prevent the rust that won't ruin the pads?
Kind hoping you tell me nothing so I have an excuse to stop this put away for 3 month BS in the winter and can just go drive it.
drive it to the store and back. seriously.
Straight answer to your question is "nothing."
Wanna get rid of the rust "lickety split"? Drive it.
Received 5,416 Likes
Next time, after you wash the car, blow dry your rotors with a leaf blower, or buy the fancy-pants Master Blaster car dryer. This will reduce the normal rotor rust a lot. But, yeah, a quick drive too works.
I definitely don't think they were wet. Already do the leaf blower thing and took it for an hour drive before I stored it. Condensation maybe?
Sounds like I get to have some fun today... Happy New Year !
if there is any moisture in the air whatsoever, you will see surface rust appear. It's a given.
They are steel rotors. They oxidize when exposed to the air. As said above, drive the car and it will be gone. If you don't want to drive the car, then sand them by hand weekly. Or just sell the car and you won't have to loose sleep over this any longer.
There is nothing you can do about this, short of replacing them with carbon ceramic brakes. Bare metal rusts immediately, when exposed to any amount of moisture--including the natural humidity in the air.
Spraying something on the rotors will only degrade your braking performance. You'll either have to live with it or drive the car more often.
You should use an indoor cover in a garage. The way doesn't trap moisture underneath. The outdoor covers are waterproof.
There is no harm in the rust. Will come right off in first drive. No harm to pads or rotors.
Now .... before you cover it, spray this stuff on a cotton cloth or whatever, and wipe the rotors with it. You can spray too if you can't reach. Definitely helps with not having rust form. I use it. I prefer the wipe on method to keep the product limited to the rotor surface.
Most of the online guys carry it.
http://www.autogeek.net/hydes-serum-rust-stopper.html
Originally Posted by cosm3os
Seems like a lot of effort to remedy a harmless occurrence. Or have we gotten that ****?!
It's not your car and nobody is asking you to do anything. He has a question/concern, other people chime in. You don't like? Ignore.
You suggest sanding the rotors?? Really
Check a dealer's parking lot, and many of the cars will have rust on the rotors. Wash the car and rust will be on the rotors within a few minutes. I wash my wheels last, and use a blower to dry the car and wheels but rust will still appear on the rotors. So I take a quick drive to remove the rust from the rotors, and then clean the rust particles from the wheels after returning home.
Originally Posted by jkw911
Seems there is only rust on the rotors after the car is washed and parked overnight. What bothers me is the brake dust so I've ordered new rotors and ceramic pads to install.
I'd rather keep the performance personally.
If you live in high humidly areas like FL, the rotors will rust just sitting. It's not a big deal overall and doesn't ruin anything. Same with cars sitting outside in the rain, etc.
