need replacement rear tires
I own a 2011, 911 carrera and the rear tires need replacement. I bought it new and this will be the first time. I got 18,000 miles out of them. They are OEM Bridgestone Potennza. I don't drive it hard or at the track. I would like recommendations for a smooth, long lasting tire. I have been advised not to switch brands or model with the fronts which do not need replacement at this time. Recommendations would be appreciated. I live in Pennsylvania and do not drive the car Jan. thru April. Thank you.
Your car is now 6 years old. Regardless of mileage, you should replace all four tires based on their age alone.
I recently purchased a set of Bridgestone S04 Pole Positions. Cost was pretty reasonable and I'm happy with them thus far. They cost quite a bit less than the "N" rated RE050A OEM tires so it won't be a whole lot more for you to get all four rather than get a matching set of OEM rears.
Your car is now 6 years old. Regardless of mileage, you should replace all four tires based on their age alone. I recently purchased a set of Bridgestone S04 Pole Positions. Cost was pretty reasonable and I'm happy with them thus far. They cost quite a bit less than the "N" rated RE050A OEM tires so it won't be a whole lot more for you to get all four rather than get a matching set of OEM rears.
6 years....is this really true??
Although I agree that tires should not be used past their recommended life cycle, but is there a typical rule of thumb? My Michelin's are now at the 8yr mark, but I still have way over 50% tread remaining. I was considering replacing them this year, but on a whim consulted Michelin's website for more info. They stated to replace after 10 years, regardless of tread. You guys agree?
Sorry to get slightly off topic.
If you decide to go with a non "N" rated tire, your Porsche dealer will not supply or install them for you.
Michelin PS2 are the OEM for my 09 C2S. Michelin PSS will last longer with as good traction, cheaper but they are not OEM spec.
I would replace all with Bridgestone S04. Not OEM but still a good tire and rated higher on tire rack. Have them on my car, no issues. A full set is roughly the same price as 2 new rear potenzas on tire rack. Then you have the fronts to hang on to just in case.
S04's are highly rated. Wouldn't bother me a bit.
http://www.tirerack.com/tires/tirete...jsp?techid=138
Several European vehicle manufacturers of high performance sports cars, coupes and sedans identify that "under no circumstances should tires older than 6 years be used" in their vehicle owner's manual. However, it should be noted that European recommendations must include driving conditions that include roads like the German Autobahn, which allows vehicles to be legally driven at their top speeds for extended periods of time.
I had a 6 year old tire on my pick-up come apart at 80 MPH on a family vacation this summer. It was always properly inflated, had no visible damage, and still had tread remaining. 5 years will be my limit for tire dates from now on.
I bought a set of 4 new ones as sonn as I returned home and used the one I bought on the trip as a spare.
As far as a six year old tire coming apart - it happens to brand new tires too, could have been an internal defect, not age.
See my post here, which links to a couple of other threads you might find useful. I'm in a similar situation (and same general area) as you. FWIW, I went with the Bridgestone S-04s (19" Turbo rims) for my summers, and the Pirelli Sottozeros (18" dedicated rims) for my winters.
Summer tires:
https://rennlist.com/forums/997-foru...l#post13789059
Winter tires:
https://rennlist.com/forums/997-foru...w-winters.html
I read a LOT about this on here. For every 3 people you ask you will get 4 opinions, but ultimately there is a very strong consensus that these are good tires.... All 8 just got dropped shipped by TireRack (basically overnight -- those guys are QUICK) to my indy for install...
Good luck.
P.S. Damon, at TireRack, who are sponsors on here, is very knowledgeable and pleasant to work with. Give him a call, he will answer any questions you have.
Summer tires:
Winter tires:
Good luck.
