Seat removal with observation
Old 04-04-2017, 12:22 AM
911sAce
911sAce's Avatar
Hi dgetz993, I have a 991 and I just removed the driver seat so I can get to the wiring under the carpet. I noticed in your picture your carpet is gone showing you the black plate. In my car, my carpet is there with slits cut out, almost like it was perforated. Do you know if I am supposed to cut the rest myself so I can reveal rear-end electronics control unit?
Old 10-11-2017, 02:26 AM
newold_m
newold_m's Avatar
This seemed like an appropriate thread to post. Planning to purchase manual 997 sports seats (power recline only) to replace the standard ones I currently have and the seller is not sure if they have heating or not. Looking at the connector pictures below is there a way to confirm if they have heating? Thanks a lot in advance!
Old 11-22-2018, 07:49 AM
sirtom
sirtom's Avatar
To remove the front plastic seat rail covers, do they just pop off with a screwdriver to reveal the E12 bolt?
Originally Posted by nwGTS
Driver side:
Remove front plastic seat rail covers. Remove front two and rear two bolts. Disconnect yellow airbag connector. (Optional: disconnect heated and powered seat connector) Remove seat.
Passenger side:
Remove front plastic seat rail covers. Remove front two and rear two bolts. Disconnect yellow airbag connector. Disconnect weight sensor connector (Optional: disconnect heated and powered seat connector) Remove seat.
So, really the only difference is the passenger side has the weight sensor connector.
Put pads EVERYWHERE. Dash, doors, sills, steering wheel, center console.
Those seat rails just love to stick out and scrape or scratch things. Also keep your hands clear of the slide release handle for obvious reasons.
It's take 30-45 minutes to remove both seats alone.
Old 11-22-2018, 09:48 AM
wc11
wc11's Avatar
Not surprised with the weight what with steel frame, all the motors, heating and/or cooling elements/fans, wires and stuff.
While the 500+ way power adjustable adaptive sports seats are awesome, once adjusted, how often are they really readjusted ?
Seems like a lot of useless excess weight.
Old 11-22-2018, 11:42 AM
Petza914
Petza914's Avatar
Received 6,552 Likes on 4,167 Posts
On a longer trip, I move the seat position around fairly often to change, and the power switches and angle adjustments.
Old 11-22-2018, 10:42 PM
sober_owl
sober_owl's Avatar
i did the same.. just did my rollbar too.. what a pain that was to line up.. at least for me
Old 12-02-2018, 11:34 AM
Viper pilot
Viper pilot's Avatar
When removing power seats (14 way or 18 way for example) is it necessary to disconnect the battery first?
Old 12-02-2018, 11:59 AM
Petza914
Petza914's Avatar
Yes, but leave the battery connected so you can move, lower, raise the seat to access all the volts. Once you have all the bolts out, disconnect the battery, then disconnect the connectors under the seat. After disconnecting the battery step on the brake pedal a couple times to make sure there's no residual current in the system. If you remove the yellow airbag connector before disconnecting the battery, you'll get an airbag fault that takes Durametric or a special scanning tool to clear and there's a chance you could deploy the airbag.
ohmyggg (07-03-2021)
Old 12-02-2018, 12:36 PM
Viper pilot
Thanks for your reply and suggestions. There seems to be several suggestions floating around that it may not be necessary to disconnect the battery prior to unplugging the seat yellow connector if one is careful not to insert the ignition key into the ignition during disconnect or while the seat plug is disconnected. Any thoughts on that? Also, I read some where that if one wants to disconnect the battery to first obtain the 'radio code' so that the code can be used when reconnecting the battery. Is that a concern?
Old 12-02-2018, 01:19 PM
Petza914
Petza914's Avatar
I always err on the side of caution when working around anything explosive, like an airbag device. Even if the hance of it deploying is less than 1%, I'd rather not risk the injury or the replacement cost when it takes 2 minutes to disconnect the battery.
No need for a radio code doing a simple disconnect. I've done it a dozen times in my 997s.
Old 12-02-2018, 01:32 PM
Viper pilot
Okdoki, thanks again for the info. Totally agree to be extra cautious when working with systems continuing the airbags.
Old 12-02-2018, 01:35 PM
Hella-Buggin'
Hella-Buggin''s Avatar
I've never disconnected the battery an do swap my track seat back and forth at least twice a year .
Old 12-02-2018, 01:57 PM
Viper pilot
Do you unplug the fuses that are for the seat adjustment motors and control units?
Old 12-02-2018, 03:06 PM
Hella-Buggin'
I don't. I just Plug / unplug it with the key out of the ignition.
Old 12-02-2018, 03:30 PM
Viper pilot
Ok great! Good to know. Appreciate every one's comments/suggestions.
Quick Reply: Seat removal with observation
