Reset service light
Old Jul 18, 2016 | 08:54 PM
teddysam1's Avatar
teddysam1
There is a guy (911 Dave) on the 993 forum selling a Durametric (enthusiasts kit) for $225 used. Enthusiasts kit has a total of 3 Vin useage. One has been used, two left to use. Fwiw
Old Jul 21, 2016 | 05:40 AM
Satch99's Avatar
Satch99
I have tried & tested the iCarsoft POR-II on a 997 & 991 for main systems (engine, abs, airbags, transmission) plus oil service reset and worked fine.
http://www.diagnostic-world.com/page...4&p=111381.cfm
Thanks..
Old Jul 23, 2016 | 12:03 AM
frankyluis23's Avatar
frankyluis23
Originally Posted by Lvt19672
So it won't work on 2005 or 2006?
These are the choices you get.
File Type: jpg
Old Jul 23, 2016 | 12:08 AM
frankyluis23
Originally Posted by Mcjimmy33
i will second the x431r found on ebay can reset it. worked on my 2008 c2s.
Just curious, what happens if you try to reset the "Service Now" alert, when the alert is inactive? In other words, can you reset it even when it doesn't need to be reseted?
Old Jul 23, 2016 | 04:16 PM
SWO Daddy's Avatar
SWO Daddy
Originally Posted by frankyluis23
Way to go everyone. Because of this thread I just ordered a Launch x431R from Newegg. Total cost was $45. BTW, it will only work on model year 2007 and greater.
I'm debating one of these x431r's as well and the way I read "MY (model yr I'm assuming) less than or equal to 07" means it will work fine on 05-06 997's. Am I off here?
Old Jul 23, 2016 | 04:21 PM
Lvt19672's Avatar
Lvt19672
Can someone with an 05 or 06 please confirm.
Old Jul 23, 2016 | 04:39 PM
F308gt4's Avatar
F308gt4
Will the x431r from newegg also reset the airbag light?
Thanks!
Old Jul 25, 2016 | 02:03 PM
ChicagoSpeed996's Avatar
ChicagoSpeed996
I actually just purchased one. It came in Chinese! So I had to use an OCR to read the menu and get to the language menu. I removed my service required light (I forgot what it said, but basically my 60k mile service light). It has a menu item for steering angle, oil lamp (which is what I used), and one more option, I forgot what it said. I don't remember if it was airbag or not. The website does not indicate airbag light, but it might be the same as a service indicator light in function?
Old Jul 25, 2016 | 04:13 PM
Lvt19672's Avatar
Lvt19672
Yours is an 07 I see, so the mystery still remains if it will work on MY05 or 06.
Old Jul 28, 2016 | 07:55 PM
Minok's Avatar
Minok
Thanks..
By "worked fine" I assume you mean "it turned off the oil/service light reminder".
Not that it set the values for when that reminder should come on again, to a value I got to specify.
Old Jul 29, 2016 | 02:03 PM
frankyluis23
X-431 R...
I did a 2009 C2 this weekend and the results are below. The first pictures shows the mileage and "Service Now" alert active. After going through the scan tool steps, the last picture shows the same mileage but with the new extended time before service. Someone will have to test it out model year 2005/2006
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jul 29, 2016 | 02:33 PM
steel968's Avatar
steel968
so the durametric software needs a special cable, it won't work with a regular usb ODB2 cable?
Old Aug 10, 2016 | 05:43 PM
ColoradoMark's Avatar
ColoradoMark
Default x431
FYI:
I bought the Launch x431. When I went to use it I was getting an error message about the ECU.
Then I remembered my car was from Canada. When I put the units in as kilometers instead of miles it all worked just fine, except I needed to reset my digital speedometer back to miles per hour on the dash display when I was finished.
10,000 km's to my next oil service.
Old Aug 10, 2016 | 11:24 PM
Bruce In Philly's Avatar
Bruce In Philly
Durametric's software is free... anyone can download it. The cable is proprietary.
Peace
Bruce in Philly
Old Aug 11, 2016 | 08:45 AM
Ericson38's Avatar
Ericson38
  • Less than or equal to 2007
  • Equal to 2008
  • Greater than or equal to 2009
