2006 997.1 C2S D Chunk woes
Old 04-20-2016, 04:08 PM
  #46
myw
myw's Avatar
june will come in no time brother. and we cruise again!
Originally Posted by Arthur Li
Not much update at this time except that the block has been disassembled. LNE has shipped an empty crate to my mechanic. Once it arrives, my mechanic will package the blocks in the crate and ship it to LNE to work on. Most likely the block halves won't be back from LNE until June.
Mechanic gave me a full breakdown of what I'll be getting. Here's a summary off the top of my head:
-get the block sleeved with the nikasil 4.0 + pistons, rings
-heads machined
-IMS from LNE
-bearings from LNE
-new gaskets, bolts, hoses, chains, water pump, oil separators
-new plugs, coils
On the list of considerations:
-IPD Plenum
-not sure what else???
Old 04-20-2016, 04:10 PM
  #47
artyve
artyve's Avatar
Originally Posted by nwGTS
So you'll have a 4.0 M97 build then?? Is that correct? Different rods? any idea what the bore and stroke will be? This is AWESOME if you are going to 4.0! Would love to see and read more about this. Not many do this upgrade (though yours was of necessity). So, sharing this with the community would be a nice treat.
Well, that's the plan. I'm excited, but very scared that it will all blow up in my face should things not work out. Not sure what the bore and stroke is, but I believe Jake Raby or Sneaky Pete may know. Not sure if I need new rods yet. My mechanic said that his machine shop will do an assessment to see if the rods got stretched or out of spec. If they are, then I'll need to get new ones I think. But if it's ok, I'll just reuse existing.
I'll share whatever I can and try to document here as complete as possible.
Old 04-20-2016, 04:14 PM
  #48
artyve
artyve's Avatar
Originally Posted by Sneaky Pete
Art.....you will likey this ALOT! Shameless plug now, I will have a used IPD comp plenum and GT3 TB available in June. PM if interested.
Sending PM your way...
Old 04-20-2016, 05:00 PM
  #49
Sneaky Pete
Sneaky Pete's Avatar
If I recall the bore is 101mm. I'm sure LN can fill in the blanks.
Old 04-21-2016, 06:44 AM
  #50
krispe
krispe's Avatar
Sneaky Pete - Why are you selling the Comp IPD andGt3 TB, what are you using instead? I thought the larger IPD and GT3 TB would be best for a 4.0?
Old 04-21-2016, 09:27 AM
  #51
Sneaky Pete
I found a X51 intake manifold and plenum to replace the IPD. It came with a GT3 TB so now I have 2. The slope keeps getting slipperier.
Arthur......sorry for the temporary derail.
Old 03-30-2018, 07:51 PM
  #52
ecostellodo
ecostellodo's Avatar
any update?
Old 04-01-2018, 02:53 PM
  #53
myw
myw's Avatar
Originally Posted by ecostellodo
any update?
arthur doesnt post too often, but his car has been back on the road for 1.5 years now - the block was bored out to 4.0+nickies i believe at LN engineering , and the engine was re-assembled (with certain parts upgraded back here in toronto).
she lives! this was taken right the he got his car back, i think oct 2016
Quick Reply: 2006 997.1 C2S D Chunk woes
