Is this just an utterly bad idea for a daily?
I have a Borla setup now. C4. Not raspy enough, not furious enough. So x pipe ala Sharkwerks or Tubi etc? Really bad idea for putting around town?
With Sharkwerks, they work with Porsche Sports Exhaust so as long as you use PSE button, the sound will be nearly stock when flaps are closed around town. Above 4000rpm, even with flaps closed, you'll hear a louder buz. With flaps opened, there is an apparent increase in sound opened or closed but definitely more so when opened. The tone responds to throttle application mostly and is of a higher pitch compared to say a V8 muscle car tone. I think Sharkwerks has done a great job.
Watch "Before/After Sharkwerks Exhaust of a 997 GTS" on YouTube
Is the question about center muffler delete on .2 ???
I have Borla on 997.1 S .... which never had a center muffler. Point being that I can speak to how a Borla sounds without a center muffler.
Ha. Love how no one is answering OPs question.
Firstly, here's my PSE equipped GTS at WOT w/ and w/out Sharkwerks bypass:
To your original question, can you clarify your current setup?
997.1 or 997.2?
Is that your car in the picture or what you are looking to do?
Really confusing OP. You need to clarify what you have and what you are trying to achieve. No mind readers here.
997.1 or 997.2?
Sharkwerks Bypass - 2012 Porsche 911 997.2 GTS - YouTube
997.1 or 997.2?
997.1 or 997.2?
Borla system on a 997.1 that's it. Fabspeed cold air upgrade kit. I was wrong I don't have PSE.....BUT I believe this is what I want:
http://www.fabspeed.com/porsche-997-...-bypass-pipes/
If I had a 997.1, I'd get fabspeeds "cold air" intake. There''s room for gain plus he sound from the cabin is great. Probably little performance gains to be had for 997.2s, especially little for the GTS or x51s.
Well, I have the non-PSE on my base 997.2. I installed the Sharwerks X pipe in December and it is definitely a step in the right direction but could use some more growl. The Fabspeed bypass is probably a bit much so I think I will go with the Fabspeed side mufflers as they look to be good quality and sound more like the PSE.
I hope I don't **** off the gods of mixing and matching SharkWerks and Fabspeed!
I have the intake already.....you would remove the mufflers simply, leaving cats then short pipes afterward. If it sucks. Reinstall.
Subtract -26lbs
That was simple....now why do I need $500 Fabspeed pipes? Have not driven it yet. Sounds better in person.....this was quick and dirty.
