FYI on costs for a PDK clutch oil change
#136
That exact article causes the confusion - it's hard to argue with pictures of the actual car:
Perhaps it's different for 991s, but for 987.2 it's the way I said.
#137
Maybe this image will help clarify which fluid is where in the PDK. This is a Porsche publication.
#138
#139
Easy to get confused here. Fremont Porsche explained it to me as stated in my repost above.
StormRune makes a very valid argument and the Porsche diagram he supplied seals the deal.
I suspect when Gunter told me differential, he actually meant ALL gears.
#140
I contacted Autel and they confirmed that the Maxisys MS 908 and MS 905 scanners can activate the pdk fill modus.
Based on the description of the special filling process I am not sure if the car must be on the ground or up on the lift when you are checking the fluid level. Can anyone explain?
Regards,
CF
Regards,
CF
#142
Regards,
CF
Regards,
CF
I suppose , if you measured how much you took out from the drain hole you could add that much back in thru the fill hole, thats if the actual volume when full isn't above the fill hole.
#144
So let me argue In the photo you show, those are the computer-controlled solenoids that control the hydraulic fluid flow that is used to move the gears into their positions. Those are not gears. If you think about it, high load gears couldn't survive direct contact as well in hydraulic fluid. They need gear oil. A completely different thing. Remember that at the gearing level, the PDK is still constructed like a manual transmission and those use gear oil not ATF (hydraulic fluid). Yes the shifting can be automated by the computer, but it is not built or lubricated like a conventional automatic transmission (which typically do use ATF throughout), so I assume that is where the confusion is coming from.
As said earlier - perhaps for 911 the PDK is different. I would be surprised but diagram suggests so.
For the Boxster the PDK fluid goes into the chamber colored blue - so the only possible conclusion that PDK clutches are located in that chamber.
For the red colored chamber they've put in my care a regular transmission oil, and only 800cc or so of it. No way that PDK clutches are there.
#145
This diagram is not correct for Boxster.
Then get back to us. And post a picture of the PDK capacities from your manual!!!!!
#146
i'm getting this info from the PDK gearbox fluids change that i did few weeks ago. at the official dealer of course.
not theory - actual results.
#147
The manual is vague on capacities.
It says ATF clutch total filling capacoty is 5.2L.
Then it says change quantity is 0L. Fill according to filling specifications! (yes it has an exclamation point)
#149
There is an exclamation mark as the only way they want it filled is with a PIWIS In the PDK FILL MODE. So it then depends whether the pan was dropped or not, and how the clutch fluid is drained.....will determine how much will be required.
#150
And the biggest thing is you apparently are lacking proper knowlege about the PDK or a transmission. Your remarks about where the gears and clutch's are gave me quite the laugh. Do you know what a clutch pack looks like, and what 7 forward and 1 reverse gears might look like? You honestly think porsche and ZF would design 2 totally different PDK's switching the clutch and the gears position around? I think not, and thats being nice.
Yes, this is one of the reasons for so much misinformation.
Think of it like a manual transmission with two computer controlled hydraulic assisted clutches. These solenoid, valves control the hydraulic engagement of the particular clutch plate. One operates the even gears and one the odd. Thus you get almost instant gear changes as 2 is already engaged when your in 1 and just waiting for the appropriate rpm. Not exactly but trying to make it simple. Thus you need / use a transmission gear oil like 75w90 in the gear portion of the transmission like a manual transmission. And a transmission hydraulic oil in the clutch portion.
