2011 997.2 GTS Engine pronounced ticking noise
Saw this post last night so this AM (outside temp in the 40s) I started the car to see if my 2011 GTS does the same. It did make a clicking noise but not as loud as OPs video clips. Once I got to work (20 mins / 12 miles drive), the sound is gone. I am guessing it's b/c of the cold weather/engine. Also, the car has been sitting in the garage for almost a week.
Its normal. My 2010 997.2 has done the same since new. I asked the Chief mech at my dealer before delivery and he confirmed normal. Read once that a little heavier oil would solve it. Had the car serviced there for 5 yrs and they always used the 0w40 weight. But recently had the oil replaced at independent shop and they recommended 5w40 Total (So California). The ticking noise is gone. Apparently the lower viscosity number of the total, 5w is thicker than the 0w for the cold operating range, and helps keep the valves quieter, per the mechanic. Its a recommended oil viscosity by Porsche, so no problem there either.
best
best
I'm with you, normal valve train noise. Not normal in the sense they all do it (although, to a greater or lesser extent they do) but in the sense its not abnormal, i.e., indicative of imminent massive repair bills.
Although, as per above, if you want to persistently chase down every imperfection to the point of engine replacement, then it can be.
I would set aside any fears of repairs and simply ask myself the obvious question: can I live with and enjoy this car even if its always going to sound like this? Because don't be surprised if it does.
I don't like it, but I've had it for maybe 60K of the 93K now on my 2009 C2S. I am not worried.
Peace
Bruce in Philly
Even with the CPO, I knew that something was stinking in the State of Denmark, so I didn't buy it. But someone sure did, as the car is no longer available.
Instead, I bought a new Panamera GTS; the last NA V8 true Porsche engine. I just have a feeling that Porsche will switch to all bi-turbo engines in this lineup as well, but worst of all, it will be all Audi-borrowed engines tuned to sound somewhat like Porsches. If you ask, I'm not impressed with the V6s in the Cayenne GTS, so are a lot of other people as well.
Op - See the below comments from another "ticking" thread. Not sure if its related but it seems to make the most sense seeing as how the ticking goes away after revving: Originally Posted by Mumbles View Post
So.... I was told by the head mechanic that he knew exactly what it is. It has to do with air that is allowed into the exhaust ( CO2 sensors ? ) enabling to burn off excess fuel. ( Located at the top of engine, left side thckened black tube ? )
This is why it only happens some of the time, and not all of the time. Perfectly normal operation.
Correct technical term...EVAP PURGE SOLENOID
Neil
Neil
Interesting you say this because I have the exact same tick if it's below 40 while the car first idles and it isn't as pronounced if it is warm outside. Goes away after the oil is warmed up. Took it to a dealer after my first week with the car and they told me this EXACT same thing:
I also mentioned the noise to my track prep indy and he said the EXACT same thing unprompted.... EVAP Purge Solenoid
Very easy to tell. If the ticking follows the rev (slight rev, not to 5k), it's NOT that evap purge valve, which is controlled by a PWM signal from the DME and it's not engine rev dependent. In general, the evap purge valve ticks much faster than the valve train type ticking.
My 2011 GTS (purchased last month with 26k miles) does not make that noise on cold startup.
I would have it sorted before getting the car.
