Reporting Problem W Motul 5-40
Old 11-03-2015, 12:19 PM
gpjli2
gpjli2's Avatar
Default Reporting Problem W Motul 5-40
Been using Motul 5-40 for years. Last fill done with X-Cess, prior ones were X-Clean as I recall. Immediately noted oil pressure gauge remained pegged even when warm at idle. Was about to replace gauge but saw a post by fellow user describing same experience. Changed out oil today after 1000 miles forMobil 0-40. Oil pressure now is reading as 'normal', 5 on start, 1.5 idle warm, 3-5/rpms on road.
I have no idea what this means regarding Motul X-Cess or rest of line. I am concerned about long term effect of high o p esp since oem setup will bypass
filter under certain conditions.
Any thoughts here?
Old 11-03-2015, 12:32 PM
motopix
motopix's Avatar
Been using X-cess for 2 oil changes. On first change my pressure gauge started acting weird and I suspected the oil (previously had Mobil1).
Replaced pressure sensor/sender at last oil change - again with Motul X-cess and pressure readings are back where they should be.
So I don't think it was the oil. But it is strange that we both experienced a sensor failure when the oil was changed.
Old 11-03-2015, 01:03 PM
Quadcammer
Quadcammer's Avatar
Received 1,406 Likes on 814 Posts
possible wrong weight oil put in the bottle?
Old 11-03-2015, 01:34 PM
Hella-Buggin'
Hella-Buggin''s Avatar
5w/40w X-Cess is what I've been using. I'm sure that's what's on the approved list. I've never heard of X-Clean.
Old 11-03-2015, 02:27 PM
mikeborden
mikeborden's Avatar
X-Clean was/is on the approved list. I think, don't quote me, the X-Clean can be used for Diesels as well.
Mike
gpjli2
gpjli2's Avatar
You have to wonder. Straight 50w? Glad I got it out before winter.
Old 11-03-2015, 02:31 PM
gpjli2
gpjli2's Avatar
Mike
I Emailed Excellence last year and advisor said both were fine. When I called Motul they hung up on me.
Old 11-03-2015, 02:33 PM
gpjli2
gpjli2's Avatar
Maybe it was your post that got me thinking. Did not replace gauge though.
Old 11-03-2015, 02:43 PM
motopix
motopix's Avatar
I hadn't posted my experience before and only recently had the sensor replaced. Not the gauge, just the sensor on the engine. It's about a $60-$90 part.
Old 11-03-2015, 04:22 PM
mjsporsche
mjsporsche's Avatar
I would not stray from using Mobil 1. Not sure what you gain with Motul, and other oils.
Old 11-03-2015, 06:51 PM
Luxter
Luxter's Avatar
Oil pressure sender / gauge combo acting up. I get it often. Too lazy to replace. Nothing wrong with Motul.
=L=
Old 11-03-2015, 07:32 PM
WV997S
WV997S's Avatar
What year is your car and is it an "S?" Thanks
Old 11-03-2015, 07:57 PM
motopix
motopix's Avatar
2006S first went to motul at 114k miles
Old 11-03-2015, 08:00 PM
cvtbenhogan
cvtbenhogan's Avatar
Same issue when I first filled with motul. 4-3 bars first couple days. Now at 1.5k miles it's at 2 bar when at normal operating temp. Noticed a couple times just under 2. Seems to be no oil consumption compares to M1, which was low anyway. Will be interesting to see the the UOA when it's time for the next change.
Old 11-03-2015, 08:19 PM
chuck911
chuck911's Avatar
Why use anything but Mobil-1? Lesser oils for lesser cars, I say.
If you're worried about oil sometimes bypassing the filter you might want to look into this http://www.pelicanparts.com/catalog/...ENGoil_pg1.htm
Quick Reply: Reporting Problem W Motul 5-40
