The 997 Targa Thread
I took most of the front passenger interior trim off and pulled back the A pillar trim (did not remove it) The sunroof drain paths are intact and there is no water on them or in the A Pillar trim itself. There is water on the sunroof drain INSIDE of the passenger compartment, but it's coming from above the drain (see third picture).
Also, to clarify there is not a significant amount of water "inside" the Targa roof(where the sunroof drains are) So this again confirms my suspicion some other seal is bad and allowing water to leak into the car frame/A pillar itself.
I'm still waiting to test the windshield seal as I spent the majority of yesterday taking apart the whole internal passenger side of the car. I will mask off all the Targa specific seals with towels and pour water around the passenger front windshield seals to see if I get any water intrusion. I'm also wondering what else I can see should the windshield be removed. I.e. if I could look up into the A Pillar frame and at the front of the Targa roof assembly to see channels where water could be coming through.
I looked up the workshop manual to replace the Targa roof seals..... looks terrifyingly labor intensive (read $$$$)
PS: I find it humorous whatever that component is that is covered in plastic. That was from the factory (presumably) so maybe Porsche knows this stuff leaks
I have a painted center console matched to my exterior Meteor Grey, it is a very good option. Wears very nicely.
Stopped by the local Porsche dealership anyways and she fell in love with the used 997 Targa on the floor. Why? believe it or not, she loves the aluminum roofline strip. And the wider track of the rear, the lines in general.
So now I have "permission" to get a 911. I'm looking for, I think, a 997.2 manual 4s. Happy to be talked out of that narrow spec. I've just started looking and the pickings seem slim (and expensive) in the Bay Area.
Thoughts? Ideas?
The open air of the Targa is the big selling point. They are a bit heavier up top with the glass, so if you need a "serious" track car, this isn't it. You get what you pay for, or you pay for it later.
Thoughts? Ideas?
anyhow, so the PDK not really a factor for me. I've assumed I want an 09 or later bc i'd want the DFI engine and hopefully blue tooth connectivity.
https://rennlist.com/forums/997-foru...ield-leak.html
I actually got some gasket sealant and "squirted" it into the seal where it is loose to fill in the apparent gaps and seal it off. At first I thought my solution was going to turn out terrible (Both aesthetically and functionally) but it appears to be working and I can't even tell I did it. I haven't purposefully tested it by pouring water on it but it appears to have worked.
I think the next step would be to have the windshield seal replaced if I continue to have problems. The dealer though they could do it without breaking the windshield but I am not convinced and didn't want to take a risk (yet) as OEM glass + seal is like $1,500 or so.
Thoughts? Ideas?
Where in the bay area are you? I'm in south bay.
good to hear from you. I'd love to connect and share notes.
I am seeing several at private dealerships in NY and FL, all at very high prices. the ones at dealers are less interesting to me, albeit pricing is a lot better.
I was set on MT until my better half reminded me that we live on a steep hill in San Francisco proper. So I am now open to a PDK...
let me know how to contact you (I am new here--are there DMs?) and we can chat
FYI- 997.2 Manual cars has "hill assist" feature and it will help on steep hills. 997.1 don't have that feature.
