Windshield washer fluid
Old 05-22-2015, 12:41 AM
tomc_mets
Sir Thomas Lord of All Mets Fans
tomc_mets's Avatar
Default Windshield washer fluid
Need to top it up, or so the dash says. So, do I need some fancy Porsche approved stuff mixed with unicorn tears? Or, is the same stuff I put into my wife's pickup truck good enough?
T
Old 05-22-2015, 02:54 AM
ADias
ADias's Avatar
Your Porsche dealer sells an inexpensive concentrate. Get some distilled water and dilute the concentrate. Distilled water is needed for many reasons, too long to discuss here.
Old 05-22-2015, 07:20 AM
DB's997
DB's997's Avatar
I guess I am just doing it wrong? I purchased a bottle of Rain-X summer bug formula and just poured it into the reservoir. What a dumb-*** thing for me to do?
Old 05-22-2015, 08:25 AM
upier
upier's Avatar
T
The stuff with unicorn tears is for the high intensity washer system on air cooled 911s. The problem with the cheap stuff is the the alcohol content is too low and algae grows on the screens blocking the system. Buy the good washer fluid. I bet it will last years.
Old 05-22-2015, 10:26 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,567 Likes on 941 Posts
I use the RainX stuff..... I think it clogs the jets a bit... I still like it but then again, I like breaking the rules. (I think I will run out and check my oil level with my car tilted.... hehehe....).
Peace
Bruce in Philly
VT Blue (09-04-2023)
Old 05-22-2015, 10:59 AM
BIG smoke
BIG smoke's Avatar
Get the one with summer unicorn tears.
Winter Unicorn tears are so last season.
Old 05-22-2015, 11:08 AM
Crester
Crester's Avatar
Uhh... why does he need some special concentrated Porsche washer fluid??? Is there some special German spec???
I just use fluid from the local auto store... and surprisingly my car is still running... lol
The following 3 users liked this post by Crester:
linderpat (09-04-2023), sierra73 (09-06-2023), TerrestrialFlyte (09-10-2023)
Old 05-22-2015, 11:29 AM
Racetwin2
Racetwin2's Avatar
Washer fluid. Can't really see any benefit of using Porshe stuff. I use the normal stuff found at the gas station. Some people even take pride in only using plain water. I have actually thought about using only water due to the canvas roof but nah....
Old 05-22-2015, 11:32 AM
Gonzo911
Rat Balls
Gonzo911's Avatar
Use only the OEM Porsche Window Washing Fluid. Our windshields are sapphire crystal edged in blood diamonds. Since the Porsche OEM wipers blades are made from Narwahl *******, you can't just use "regular windshield washing fluid". Just like you don't need a license to have children, some of you people don't deserve to own a Porsha.
Old 05-22-2015, 11:51 AM
Racetwin2
Racetwin2's Avatar
Yep and for God's sake don't drive if the rain is too acid. It should be balanced PH around 7.....always test before driving in the wet.
Old 05-22-2015, 12:01 PM
Petza914
Petza914's Avatar
Received 6,597 Likes on 4,195 Posts
I use the Prestone Bug Dissolving stuff and have for years. Works fine. I don't particularly like Rain-X. Works great at first, then if used with the wipers starts to make the wipers hop and if you look carefully at where the hops land, there is actually deposited blade rubber there as well as the edges where the wiper blade changes direction. Since their washer fluid also has some of their Rain-X chemical in it as a maintenance dose, I don't use that either.
Johnnywood (08-28-2022)
Old 05-22-2015, 12:08 PM
extanker
extanker's Avatar
oh em gee.....better send a sample to blackstone....while your at it add some brain fluid for them to check. non stop elton john princess club
Old 05-22-2015, 12:46 PM
Devil Boy
Devil Boy's Avatar
I use stuff that's blue.
Old 05-22-2015, 01:04 PM
myw
myw's Avatar
LMAOOOOOO
i am crying here.
i just use whatever is on sale.
Old 05-22-2015, 01:57 PM
ADias
ADias's Avatar
Use whatever you like, but do not complain about algae and bacteria growth... You've been warned.
BTW... the Porsche concentrate costs about $8 and has lasted me over 10 years and is still going.
873/1960 (12-02-2021)
Quick Reply: Windshield washer fluid
