Was the IMS bearing issue resolved with the March '06 997?
Silly question but what is a self-adjusting clutch? It sounds like more "moving parts" which is the same reason I stay away from the 4 wheel drive versions.
From a logistical standpoint the Cayman seems to be easier to work on (easier access by lifting that engine plate) and has less features/moving parts that can go wrong but the 911 has rear seats (extremely handy in a pinch) and a much better sounding exhaust.
Of course driving a Cayman for the first time could change everything
It's something to do with the pressure plate adjusting itself for friction disk wear. Not sure what all it's doing. I believe this S-A clutch is on the S models only, not included on base Carreras.
but the Cayman has two trunks. Maybe better than a worthless back seat.
911 MAY have a better exhaust note, but the Cayman intake sound is INCREDIBLE when uncorked.
If you're looking for just a pure sports car, the Cayman may fit the bill perfectly. The mid engine platform can out handle the 911 hands down on a tight twisty road.
You need to drive both models and see which one turns your crank.
https://rennlist.com/forums/997-foru...ar-more-2.html
