SMOKE SMOKE SMOKE!!
#31
Point is,I wouldn't drive it anymore,not even start it,he could be causing more damage that way...
#33
Poseur
Have you ever owned air-cooled 911s? That's fairly typical for those versions when they sit a long time in cold weather (re: seals contract and oil pools).
If it keeps up the AOL separator(s) sound like a possibility.
#34
Hi All,
Car is at dealership for service... they are taking the engine out as we speak ($3200 OUCH!) to do a check... Sounds like you are all correct... either AOS or Scored Piston... Will keep you posted
#36
That is why no one should use dealers for any serious work. Ever.
#37
I thought the same thing but maybe they scoped the cylinders (saw the damage) and already know the engine needs to be rebuilt????
#38
Autowerks in Woodbridge On, charges approx $1800 to replace an AOS, and $380 or so for a compression/ scope test...
TheLooch is getting raped here... unless they already know it's a scored cylinder...
#40
FWIW, I believe the bore scope should only require removal of the spark plugs to get a scope into the cylinder chamber. Then the engine should be cranked over to view all cylinders completely. So I agree with others that dropping the engine is premature especially if this is an out of warranty expense.
#43
I have not personally had service done at either.
www.pwr-tech.com
www.shadetreegarage.com
#44
I've been reading this thread and feeling for you Looch - I can't imagine what you must be thinking. I hope it all turns out to be the AOS or something other than "scoring". Good luck to you! All the best!
#45
Poseur
Several years ago Porsche did a courtesy borescope job on my engine in order to get to the bottom of what I consider excessive oil usage. They never dropped the engine to do this. They go in with a borescope after they pull out the spark plugs and peek inside.
It sounds more like an AOS. That's more common.
