997 Gear Lubricant Data
Old Aug 24, 2013 | 04:48 PM
cvtbenhogan's Avatar
cvtbenhogan
Originally Posted by fastm3
I was experiencing the famous intermittent 1st gear engagement issue, so I took my car to the dealer for the following services:
1) Change gear lube (they used Mobilube according to the receipt)
2) Bleed the clutch hydraulic fluid
3) Adjust clutch cable
I would say that I don't feel any improvement, and unfortunately the intermittent 1st gear engagement issue persists. I guess at this point I have to live with it....
Its my only gripe with the 997. It's a shame in an otherwise fabulous car. A damn shame.
Old Aug 25, 2013 | 11:02 PM
fastm3's Avatar
fastm3
Sure is a shame. I wonder exactly what the issue is. Is there a problem with the synchro? In that case, how much would it cost to fix it.....?
Old Aug 26, 2013 | 06:47 PM
anewman's Avatar
anewman
During summer months I have no problem. During "cold" california winter months I simply depress the clutch pedal twice to get into 1st. works like a charm. I use all genuine porsche dealership fluids. I just pretend i'd driving a race car - oh never mind - no need to pretend.
Old Aug 27, 2013 | 11:32 AM
Luxter's Avatar
Luxter
The issue is that the gear box is a transaxle design, meaning final drive and gear box are in a single housing with very contradictory lubricant requirements between hypoid gears and gear synchros.
Many transaxle equipped cars unfortunately suffer from issues with shifting.
Old Aug 30, 2013 | 06:42 PM
fastm3's Avatar
fastm3
Thanks Luxter. However the question remains, why do some 997s exhibit this issue, and others apparently do not.
Is there anything that can be done to remedy this?
Old Aug 30, 2013 | 08:31 PM
Luxter's Avatar
Luxter
Welcome.
Honestly, with my limited experience, it probably has to do with shifting style / technique. Mashing 1-st or 2-nd pretty hard doesn't help. And if you are second or third owner you essentially have no idea how previous owner drove that car. Unless of course he offered you a ride before your test drive.
Double de- clutching always helps. I often do that going from 1-st to 2-nd when cold. It somehow helps to minimize stress on synchros.
I've seen a lot of bad std. Tranny shifting habits. Not that I'm perfect, trying hard however to prolong its life.
Again, most importantly proper lubricant, condition of your clutch, cables and bleeding will help in most cases. I cannot stress enough importance of proper lubricant. Have a look at Richard Widman's web site explaining differences between GL4 and GL5 lubricants and short section on transaxle requirements. It is quite eye opening.
Hope that helps.
Cheers,
Luke
Old Oct 16, 2013 | 12:16 PM
Luxter's Avatar
Luxter
Default Update
One more update.
This time with Millers EE Transmission 75W-90.
The VI and KV @ 0*C for this fluid don't follow the trend well, so I sorted it by KV @ 0*C (freezing point) as calculated by Widman calculator (meaning not 100% accurate).
It's one of the most viscous fluids at 100*C with relatively high VI.
It also contains Nano Technology.
Old Oct 17, 2013 | 11:41 PM
USMC_DS1's Avatar
USMC_DS1
Thanks for the update Luke. I assume that Millers should be a good fit for our mildly warm TX weather. Has anyone tried Miller's?
Old Oct 18, 2013 | 11:07 AM
RichFL's Avatar
RichFL
It would be good to add this to the DIY sticky.
Old Oct 18, 2013 | 11:21 AM
997_rich's Avatar
997_rich
One note for all: when you change your oil doublecheck the gearbox-side of the cables. The cable jacket mounts in a sheet metal bracket. Mine were half popped out causing some binding. I pushed them back in and safety wired them so they can't pop out (they're only retained by a plastic snap). No amount of cable adjustment will help if you have this issue.
Old Oct 18, 2013 | 11:37 AM
Kero's Avatar
Kero
what is the frequency in which you change the transmission oil on these cars?
Old Oct 18, 2013 | 11:55 AM
USMC_DS1's Avatar
USMC_DS1
Agreed... it will be amended to our DIY sticky.
IMHO: once/yr if you track; once/2 yrs otherwise; lifetime according to Porsche = when the warranty ends.
Old Oct 18, 2013 | 04:55 PM
Luxter's Avatar
Luxter
I recently changed my Shell Spirax G-box fluid to Millers CRX 75W-90 NT.
The first 250 kms or so were quite a bit notchy in close to freezing point weather (yes, we’re getting it already. Don’t laugh! Please…). Shifting improved quite a bit with the lubricant bedding in. I would not recommend it for a daily driven car (say, by your better halves) in moderate climates. That said, my wife really liked shifting while fully warmed up and I didn’t even solicit her opinion. It is one heck of a lubricant for track or similar higher load application. Millers received nothing but accolades for this fluid.
I would still recommend Shell Spirax for daily driven 996/7 in moderate climate that includes winter like conditions and a casual driver.
Millers has yet another fluid, that is EE Transmission 75W-90 that has far lower viscosity at 0*C. See the table above. It has NT technology and may be a better fit for 996/7 transmissions. I will be a lot smarter when I come back from Millers HQ in mid November. Please hang on with Millers specific questions until then.
Guys, all fluids above are 75W-90, all are GL-5 (many GL-4 & 5). Isn’t it amazing how much their viscosities vary at 0*C? Many (most? All?) of them are not Newtonian fluids, so the 0*C KV is only approximate, yet the bracket is still quite amazing!
Note that Millers EE Transmission does not fit well with its VI and KV @ 0*C values. I have no intelligent explanation to that. In other words its VI would suggest lower KV @ 0*C, but it doesn’t plot that way. I will ask Millers Techs for their comments.
Regarding frequency of change, many thanks to USMC for a very diplomatic and elegant answer.
I also posted some comments on Renntech. Link here:
http://www.renntech.org/forums/topic...-oil-analysis/
Old Sep 4, 2015 | 09:20 AM
Bruce In Philly's Avatar
Bruce In Philly
Originally Posted by ilko
The stock one from the dealer. I've driven a car with Delvac and even had the Liquimoly in my gear box for a couple of weeks. Very difficult engagement in first with both of those, especially when cold. So I went back to whatever Porsche sells in their service department. For street-driven cars stick with the OEM fluid.
Regarding "stock from the dealer": My indy buys supplies from a local Porsche dealer and could not get the PTX from them as they told him... kinda unbelievable.... they only use Delvac and put that in all the cars. So, you think the dealer is buying Porsche-supplied stuff and filling according to the owner's manuals.... wrong. At least this dealer doesn't do it.
My 2009 C2S manual states PTX only. If I took my car to this dealer, they would have filled it with Delvac.
I ordered the PTX from Suncoast and supplied it to my indy. $115 for 3 liters plus UPS ground shipping.
See another post on this subject here: https://rennlist.com/forums/997-foru...-synchros.html
Peace
Bruce in Philly
Old Mar 8, 2018 | 03:19 AM
Presto's Avatar
Presto
Very useful info. Thank you
