Big Gains from Fabspeed Headers - 997S
#46
Just be careful with grinding away that weld, you can weaken that joint and the material remaining will crack. My suggestion would be to TIG weld either over your grind with a fuse weld, or better yet place a few beads on the outside, where the tube meets the flange. Make sure to bolt the flange down to a flat Jig to prevent any warpage, as stainless steel really likes to pull, even the crappy grade the factory uses.
I was quite careful. Worst case, I will come back and buy your headers.
I actually really like your design. Thanks for posting all pictures. Makes a huge difference.
Cheers,
On another note, shipping to Canada, can you avoid UPS?
Say, USPS, FedEx or just about any other carrier for that matter. I'm sure other Canucks will appreciate too.
Luke
