DIY Shift Cable Diagnostics and Replacement
hello, 2nd owner 2006 997 with < 85,000 KM. Sunday today drive; pulled over on curb planning to make U turn on 2 lane roadway. stuck in first with shifter up and down no side-way play. i drove the car 50km home in first gear. the temp did not go pass 175. only 2 citizen drivers got horny with me. one copper asked me if i needed help and the other looked away like he saw nothing. looks like i be doing this.
THANK YOU VERY MUCH to INSOMIC.
hey USMC, yes I did that. btw. I played with the blue collar cable/drivers side and I heard noise from engine bay area underneath behind the rear seats, however nothing when I did the same to the passenger side black collar cable. next step be to jack up vehicle for inspection. looks like a good time to change the tranny fluid too. thank you all for your kind assistance. fatfat.
Back on the road. my cable broke at 84,900km EXACTLY where the OPs cable did as in picture posted. interesting to note the shifter has a better feel to it now. iam guessing my waterpump is next.....................AGAIN, thank you all!
The following 2 users liked this post by DC911S:
jayi836 (08-26-2019),
Tsmith5150 (02-12-2020)
The part you are showing is #17 in this 987.1 diagram. Not sure if they will fit in a 997 in a different location. For the 997 the end that attaches to the transmission is completely different. But parts #10 and #11 are the same for a 996/997 and 986/987. So if you think your play is at the cable ends just use the correct parts.
If you want to tighten up the play in the OEM shifter look at this thread from Function First instead: https://rennlist.com/forums/997-foru...our-997-a.html
Or replace the entire shifter with one from Numeric or the like: http://numericracing.com/#!/Competit...egory=12247277
And while in there consider replacing the entire cables with the Porsche Motorosports Cup car version, or with an aftermarket one from Numeric: http://numericracing.com/#!/Performa...egory=12247277
Thanks! But my car is not a 997 but a 987C
