***GROUP BUY*** SHIFT-RIGHT Solution: Ball Bearing Shifter Kit for your 997
Basic Sponsor
![](http://files.hgsitebuilder.com/hostgator894335/image/srs-playtimesover2.png)
SHIFT-RIGHT Solution: Ball Bearing Shifter Kit by FUNCTION-FIRST Performance
***GROUP BUY***
SHIFT-RIGHT Retrofit Kit regular price of $295 will be reduced to $265
SHIFT-RIGHT Core Exchange regular price of $349 will be reduced to $319
I was recently contacted by a customer about arranging a Group Buy for our SHIFT-RIGHT Solution: Ball Bearing Shifter Kit Upgrade, compatible with the 986/996/987/997 models. I’m opening this deal up to the Rennlist community, so please take advantage of the savings!
Once at least 5 people commit, the lower price will take effect and invoices will be emailed out. Following that, as people sign-up they’ll receive an invoice at the discounted rate immediately. There is no limit to the number sold. The Group Buy rate will expire August 12, so please reach out before then via email or PM.
Please be sure to include the following info:
1. Your name
2. Email address
3. Mailing address
4. Shifter unit model
5. Retrofit Kit or Core Exchange
Here is the link to the product page that outlines all the details of the kit, as well as installation instructions:
http://www.function-first.com/produc...right-solution
Please reach out with any questions. I'll be updating the buyer list at the bottom as people sign up.
***PLEASE NOTE***
South Carolina customers will be subject to sales tax.
There is a limited number of Core Exchange units in stock at any moment, so please plan accordingly - I will reach out with an estimated ship date.
Group Buy pricing is exclusive of S/H and Core Deposit fees.
Group Buy Participants
1. CarreraGuy02
2. bugeyemilo
3. Karnuts
4. The Ox
5. MaddMike
6. MC968CS
7. modoz61
8. -
9. JEI-Porsche
10. the_buch
11. BauerR
12. -
13. Gear Rower
14. Nedster
15. Hilltopper
16. heliflyer
17. Hula
18. Long Islander1
19. kk2
Comprehensive Shifting Solutions for your Porsche.
![](https://www.function-first.com/cdn/shop/files/FFP-Logo-2023-Banner_BlackBG_480x.png)
Basic Sponsor
1. cut out the OEM plastic bushings
2. remove the OEM shifter yoke
3. install the upgraded shifter yoke
4. install the upgraded shifter bushings (90deg retaining ring pliers required for this)
The SHIFT-RIGHT Solution accomplishes a different goal than the OEM short shift kit. It replaces the major pivot points of the shifter unit with aluminum components and ball bearings to remove any flex and play from those points and has no impact on the shift lever throw. The OEM short shifter, on the other hand, simply changes the fulcrum point on the shift lever for a shorter throw, and it uses all the same plastic components in the pivot points as the standard shifter.
The SHIFT-RIGHT is compatible with the OEM short shift kit, and that's actually the exact setup you see in the promotional shot in the original post above. That's my shifter
Basic Sponsor
Thanks, guys! Please be sure to send the following info, either via PM or email:
1. Your name
2. Email address
3. Mailing address
1. Your name
2. Email address
3. Mailing address
Any chance that you have a core exchange short shift version available for sale? (assuming you would accept my non-ssk unit as the exchange)
Basic Sponsor
I wouldn't worry about it!
I do have 1 spare OEM 997 SSK lying around. I'll send you a PM with details.
Basic Sponsor
Here are some before and after comparisons of the shifter mechanism, pre and post SHIFT-RIGHT Solution installation!
(Note that the BEFORE video is the stock shifter out of a 2001 986 Boxster S, and the AFTER videos are of a SHIFT-RIGHT retrofit kit upgraded factory 987/997 short shift kit. It's still an apples-to-apples comparison, since both units utilize the same bushings from the factory.)
BEFORE...
Excessive shifter play and slop, particularly in the fore/aft bushings.
AFTER...
Zero flex and zero play in the mechanism yields smooth, solid, predictable, and consistent shifter action.
BEFORE...
AFTER...
Basic Sponsor
I do have one 997 SSK that I could offer up for a Core Exchange. I'll send you a PM.
Btw, we now have enough buyers participating for the group rate to go in effect. Please reach out if you'd like to take advantage of the discount!
