Spies Hecker or Glasurit for my 997.1 factory aero kit.
Hey guys. I'm about to have my oem aero kit installed and painted in GT Silver for my 08 C4S. My body shop ( a Porsche "approved" collision center) states both Spies Hecker and Glasurit are accepted by Porsche. I saw samples of both and they pretty much look identical. My question is, is one better than the other? Is there way I can tell what brand of paint is originally on my car? I just want to make sure I get a good match. Thanks.
Paint Shop
110. Paint system; only the following brands may be used for the repair of Porsche vehicles:
• Spies Hecker
• Standox
• Glasurit
Paint Shop
• Spies Hecker
• Standox
• Glasurit
Poseur
I have used Glasurit for years and have been extremely happy with it. I have no idea what paint manufacturer is being used currently on the Carrera. One very important point when painting any car today is to allow the primer to dry throughly and settle, before you apply the finish coat. When most body work is done it is done in a hurry. As a result the primer hasn't cured and the color coat settles into the small swirls and scratches in the primer as is shrinks up. Try to get them as much time as possible between the two.
Paint Shop
• Spies Hecker
• Standox
• Glasurit
Paint Shop
• Spies Hecker
• Standox
• Glasurit
A real good painter might be able to make an educated guess as which paint is on your car. I do not know of way to know based on the VIN, options codes.
Now it might the color of your only comes from one or possibly 2 of the 3 paints but I have no solid info on this either way.
If GT silver is a metal flake paint that derives some or all of its "color" from the metal flake then to get a good blend the adjacent panels will want to be sprayed too.
Otherwise the newly painted body parts may not match up and can stand out and subtract from the car's appearance.
Sincerely,
Macster.
Basic Sponsor
Either is good quality. We use Spies for the majority of our Porsche stuff. GT Silver is available in Spies and Glasurit, and you can mix it using other brands as well.
However, one thing to keep in mind, you should meet the painter and the shop owner, and ask about formulation.
When painting lower trim (we did my lowers when the turbo arrived), you really have to tweak the formula a bit. Painting it the same formulation as the upper panels may result in finish that would look ok, but not 100% because of how light hits the lower sections compared to the rest of the car.
We tweaked the formula 9 different ways on mine (yeah, I'm **** with a capital A)....until it was what we wanted. It's NOT the same as you would spray on the doors, fenders or hoods. There is no need to blend adjacent panels IF you have a true pro doing the work - he will know how to lay this material down on the kit parts to avoid that.
But a good top notch shop will know this. The formula has to be manipulated a bit, and you should be able to come see the sprayouts to compare before the work is done.
Good luck with it.
Good luck with it.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
While we're on the paint subject, does anyone have advice on where/how to find a Porsche "approved" body shop? I asked the local P car dealer in Dayton, and to no surprise I was directed to their own collision center in another local location (which happens to be a Chevy dealer). Consider me skeptical, I'd like more referrals before I have my minor rear bumper scratch touched up by the Chevy dealership.
Porsche approved doesn't matter. Look on line and see and talk to people before making a decision. I had a pretty big accident and the shop that worked on my car fixed it beautifully.....beyond my wildest expectations! Those shops with artists are out there....you just have to do a little digging and personal investigating.
Good Luck!
Tom
Basic Sponsor
http://www.porschecollisioncenter.com/locate/index2.php
Here you go. You will find that everyone listed here uses Glasurit or Spies Hecker.
Ive used glasurit for yrs, and used other brands. I dont think it matters much what you use on a body kit. If you want the best id say use G , because its the most expensive. But youll never tell any difference on the parts.
Glasurit.
My guy restores very high end cars and that is what he used to use.
Also check and see who now makes Porsche paint.
He now uses PPG and waterborn paint but said use factory or Glasurit.
