charger connected, hood closed?
I've only had my 08C4 for one month and I've got a lot to learn, including, "how is it possible to have a battery charger connected and the hood closed"? Wouldn't the hood have to be open to let the cables through? It seems there is a way to connect a battery charger other than directly to the battery terminals. How do you do that?
Is the terminal in the fuse area involved?
Pardon my ignorance! and many thanks in advance
The alternative is to get an adaptor that plugs the charger into the cigarette lighter. Of course then you have to leave the window cracked or close the door on the cable which because of the thick weatherstripping is apparently possible as people do it.
I leave the hood ajar (I've disconnected the trunk light bulb) and have installed a semi-permanent connector ( which is fused) so I don't have to fool with the battery each time. The connector and charger I use is made by CTEK, a Swedish company which also manufacturers the charger Porsche sells. CTEK chargers and accesories of different types are available on Amazon. Their base 3300 charger is the same as the Porsche one and is about half the price. Good luck.
Battery Tender has several good options for this. You can direct connect a line to the batter and run it through to the external panel piece right below the windshield wiper.
I actually run my short wired quick disconnect through the battery cover and let it sit just below the windshield wiper nozzles. When I want to charge I pull it up and plug it in. The hood never gets opened.
USMC DS1, is there also a removal trip on the inside of that upper windshield trim to run the wire through?
I was told in a similar post sometime ago that the car is smart enough to know the bonnet is not closed and shuts of the power to the frunk light in about an hour or so and no need to remove bulb. Never stuck around at the storage unit to verify but no issues for several years.
"If the ignition key is removed, loads which are
switched on or are in standby mode (such as the
luggage compartment light, interior light and
radio) are automatically switched off after approx.
2 hours."
The light will go off in about 20 minutes if you arm the alarm with the hood open (you'll get a beep indicating the hood is open). Same holds true for the engine compartment light.
No need to disconnect the trunk light:
2 hours."
2 hours."
Unless you are parking the car for 3+ weeks and and/or only pulling it out for a short 20min drive every week, there should not be that much plugging and unpluging of a trickle charger.
As others have mentioned there are two options typically:
1) Put charger clamps on the battery terminals and run them out by the wipers... that area is outside of the sealed frunk space so no weather stripping to worry about, but you need thin cables and clamps and popping off the battery cover.
2) Get a trickle charger that plugs in to the cigarette lighter in the center tunnel, and feed the cable out via a door (and close the door on the cable).
