GTS Mesh Grille Inserts - Done
Had the FVD Brombacher black mesh grille inserts installed today The sharp-eyed will spy that I also had the vertical grille bar removed from the outer openings.
Here are a couple of sets of Before & After pics. The difference is not dramatic, but I'm happy with the change.
I did not do the install myself...my skills fall woefully below my expectations.
Looks great! I did the Lowes screen door mesh on my 06. Just makes me feel better that something is between the AC condensor and the outside world. No noticeable difference in water or oil temp.
When you remove the front bumper to clean debris out take a can of flat black engine paint and spray those radiators black.
wow looks great!!! This is exactly what I'm looking for! would you mine sharing who installed them for you? I'm some what close to LA and will be willing to drive up to get them installed!
Please PM me with where you purchased the grill and your installer info!
Thank you!
Thank you!
I drove through a 1/2 mile long storm of fornicating grasshoppers recently and when I arrived home discovered not only splattered hopper guts on the Xpel, mirrors and wheel wells but a 1/2 dozen critters crawling out the front of the bumper. I vacuumed these and another dozen or so dead ones (and the usual leaves, twigs, styrofoam peanuts and paper) inside the bumper shroud and seriously considered installing a set of grill inserts. I realize the idea of the mesh is to prevent large crud but with the guards installed one would have to remove the bumper in order to clean the interior. Perhaps periodic vacuuming vs the guards may be easier? Or perhaps install the sides for radiator protection and forget the middle panel? Or don't drive the car during hopper season?
Seems ill-advised to me...especially after reducing the airflow (even a tiny amount) by installing the mesh grids.
Could you please post some impressions of the kit (quality / durability / simplicity)?
Would sure appreciate some idea of the price of the full installation if possible.
Many thanks.
Many thanks.
I also had the FVD Brombacher grilles installed on my GTS a few weeks ago. My Porsche dealer installed them for me, said it took 3 hours. IIRC they charged me around $300 for labor - and the grilles themselves were around $260. The mechanic said it was actually a little more work to install them than he'd expected. The front bumper cover has to be removed and that's apparently a fair amount of work. The kit comes with mounting screws and a sealant (think silicon caulk) to attach the grilles.
I have PDK on my car so I had all 3 grilles mounted. If you have a manual you don't have the center radiator so in that event you'd only need the side grilles. A friend of mine who has a 6-spd GTS is having a set installed on her car today.
From what I've seen of the junk ingested by my car in the six months before I installed the grilles, I think very little of that would make it through the mesh so I'm not worried about the fact that I can no longer vacuum out the front scoop area. I track my car pretty regularly, and I was much more worried about the radiators getting dinged by high-speed debris than by a minor build up of junk (leaves, bugs, etc) in the scoop.
I really like OP's removal of the vertical slats - wish I'd thought of that.
DMoore
'11 GTS
'10 Panamera GTS
DMoore
'11 GTS
'10 Panamera GTS
My costs mirror those of DMoore. I had my favorite body shop put mine on...three hours of labor ($360). As I said in the opening post, it's not something I could have done myself.
As far as getting the small stuff that gets past the mesh OUT of the radiators...compressed air should work through the mesh grilles just fine.
Regarding the Brombacher kit, itself - the mesh grilles did not fit the openings without a little modification (nothing serious). And, the screws and sealant were not used to attach the mesh on my car. The body shop guy used compression fasteners around the edges. Should be a much more permanent installation.
DMoore
'11 GTS
'10 Panamera 4S
I went with FVD Brombacher after waiting a (too) long time for Rennline to announce their kit for GTSs.
