What did you do to your 997 today?
#6016
I would buy some additional .5" brushes as the one that comes with it isn't great.
If you are comfortable bleeding your brakes I think it would take half the time and get better results to paint them off the car. I left the brake lines on and its a pain to maneuver the caliper to get all the edges.
Spend the time to clean the brakes. I ended up bringing a bucket and hose in the garage and first used soap and water, then wire brush, finally brake cleaner.
I will send final pics when the project is done.
#6017
The Bruce,
Your calipers look great! Good job and I see you added the "PORSCHE" decals...nice touch.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I did the exact same Dupli-Color paint/decal process to the calipers on my Boxster two summers ago. I hung my calipers (using bent coat hangers) to air dry outside in the hot sun for two days and that did the trick (I brought them in at at night).
You should now be good to go for several years.
#6019
#6020
Bruce wish I had known you were doing this. I've done this many times and learned the hard way. VHT Red is the answer in spray form. It is almost an exact color match and dries super fast. Dupli-Color is a PITA. I've tried it and started all over with VHT. Then I put the stickers on and clear coat with Rust-Oleum Engine Enamel. Either way though it is a rewarding project and yours look great now, just the waiting for drying wasn't fun
The calipers look great but I've had major issues working with Duplicolor. I would not recommend it.
Its humid out and the calipers still weren't cured after 36hrs. I put clear coat on the first caliber and watched in horror as it started to orange peal and crinkle up the the caliper paint. I thought I was going to have to sand it down and start over.
Luckily when the clear coat started to dry the paint laid back down. I hit it with a blow dryer to get it the last mile. Its now back to 95% and nobody but me would notice.
I called Duplicolor customer service to find out what the deal was and they said the humidity was affecting the cure time. They recommended either baking the caliber or going out for a 20min drive to heat the brakes up, then putting the clear coat on.
![](https://cimg9.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_0936_68f97d9f8f930b6cdabcd7d3f143a5d5b57eb429.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_0943_187f24f85749f69b9adda81e1c8b8a2118268b7a.jpg)
Disaster averted. It orange pealed after putting clear coat on. Luckily it disappeared after the clear coat dried.
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_0947_c38b8210758be4b9db6f4676e8fa14af58a89b71.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/img_0952_0caad0fb8321fdb3dc150cca33c087376b8b99e0.jpg)
#6022
#6025
Installed new black leather OEM shift boot and ****, but the boot was a bit twisted and not lined up once it was installed. So I took it back off, took the boot/**** apart, rotated the boot a bit and then put it back on. If you ever do this, the **** twists a bit, then you pull it off the boot. Then a small plastic ring needs to be taken out that releases the leather from the piece that connects to the ****, under it.
#6026
how did you do it? I am trying to install forward facing seat but I am not sure how to hook it up? I cannot find seat latches
#6028
This way uses just the belt/belt path designed carseat. Front facing I'm not sure about but I know there are many threads and it is reportedly easier for install and everyday use. Good luck!
#6029
Installed the Fabspeed Competition breather on Sunday. Then went for a nice country drive. Oh baby! Sound aside (which was really cool), I could feel the HP lift. As a DIY project, it was easy! Just have the tools and study then follow the furnished instructions. Comparison pictures attached.
#6030
Basic Sponsor
