What did you do to your 997 today?
#572
LOL took me forever, as first times of anything usually do. But the motive bleeder worked like a charm.
IIRC brakes on the base & S are pretty much the same design, the S just gets beefier parts.
(And I know that because I once misordered and got an S rotor by accident. Didn't realize it until we found the caliper wouldn't fit on it! Duh.)
#574
I know the feeling! I have had several incidents like yours with prior cars. Hand in there and it will get better. How did it occurred?
#575
Today, I replaced the engine air filters.
#576
Looks like it's DIY season!
#577
Today I changed to LED license lights.....removed and cleaned all the residual from removing the tag stickers from the mirror (from texas) opened my box of wheels that arrived...Forgestar F14...piano black...TPMS arrived as well....Monday...to order tires and Europipe exhaust.
#578
AND.... I still saved $$$ because of this forum and the DIY posts, so that's AWESOME!!!! BIG THANKS (AGAIN) TO ALL WHO CONTRIBUTE!!!!
#581
I cleaned out the front radiators. I've had the car for three months and figured the dealer probably cleaned out the radiators when they CPO'ed it. WRONG! I was shocked at how much crap was in there. Especially since the oil temp never gets over 200F, even at sustained highway speeds on warm days. I nearly filled a small grocery bag full of leaves, butts, stones, twigs, etc. and sucked a bunch more out with the shop vac. I wouldn't have thought there was enough space in there for all that crap!
#582
Sounds like a book I read as a kid called Fortunately
![Name: fortuneately_zpsf614f172.jpg
Size: 34.0 KB](https://rennlist.com/forums/attachments/997-forum/1206229d1501335617-what-did-you-do-to-your-997-today-fortuneately_zpsf614f172.jpg)
Today I did some DIY on my car, so that's good.
But I sheared off one of the three bolts connecting the cat to the exhaust manifold on the passenger side, so that's bad.
But I didn't shear off the other two bolts, so that's good.
But I did the exact same thing on the driver's side, so that's bad.
But I was able to pull the cats to get better access to them, so that's good.
But the bolts are a permanent part of the cat assembly, so that's bad.
But I was able to drill the sheared bolts out and replace them, so that's good.
But it was 100 degrees out, so that's bad.
But while I was drilling out the bolts, my brother replaced the plugs and coils, so that's good.
But on reassembly, one of the exahust manifold bolts on the driver's side got cross-threaded in the block, so that's bad.
But I was able to get the other 5 bolts in properly and torqued, so that's good.
But now the manifold on the driver's side is rigged with a short bolt and a few washers, so that's bad.
But everything else went back together and it doesn't sound like I have any leaks so that's good.
#583
[QUOTE=Chris from Cali;10575967]Went to Cars & Coffee, then came home and detailed the 911... I had a little help:
What is the interior height of your garage?
8 or 10 ft?
Thank you. Love the lift!
8 or 10 ft?
#584
Went to dinner @ 7:44pm, hot in Houston.
FYI, my TPMS sensors are on order.
