Strange green fluid under car
#32
If it's exhasut gas condensate the pH will be in the range of roughly 3-9. Most likely more towards acidic. If you have enough you could test it with a pH strip.
#33
new theory...you describe it as green, but the photos look yellow.
Mt Dew Syndrome. This is where something decidedly (****) yellow appears to be green because it's dispensed from a green bottle. Very bad cases have regular Mt Dew drinkers believing all things ****-yellow are actually green. Do you drink Mt Dew?
#34
5th Gear
#35
Thanks, it try that but im pretty sure ther isnt anything in there ...but you never know. Strange thing is this never hapenned in many months until after Porsche serviced it. But thay have had it up on a ramp since and can't see any sign of any liquid. The even took me out to the worksho and showed me and it all looked dry. I then drove home (in the dry) put it in thae garage and didnt drive it for a week or so and then looked and I had another another couple of pools of yellow/green liquid. It doesnt seem to have any smell either. Strange.
Thanks for all the input. I'll get to the bottom of this somehow.
#36
There is absolutely no way that would be cat urine without you knowing exactly what it was. Cat **** is pretty pungent.
If it really drips in the same spot or spots maybe get one of those water spill sensors and maybe that'll give you an idea of when and how often it happens. I can't imagine not being able to trace a leak. It may burn off by the time it gets to a dealer but you should be able to track it down.
#37
That one photo that shows both spots in the same pic, the spread and symettry makes me think it's exhaust related and is coming from condensation from the mufflers. Question #1 - do your mufflers or cats have a weep hole for condensation to drain out? #@ - If you start the car and let it run for a couple minutes where condensation forms in the exhaust, do you see anything dripping out in those locations. Any chance you have copper exhaust gaskets at the joint between the mufflers and cats? Do you see any black exhaust residue at any of the joints that would signify a small exhaust leak? If there's a small leak and either a gasket or material in one of those components is copper or something else that turns a color when exposed to moisture, the condensation drips could be a color and not clear. Catalytic converters contain platinum, but that's a very unreactive metal and doesn't turn color which is why it's used for diamond ring settings, etc.
I love a good mystery and am now curious about this one.
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
#38
Still a mystery to me, just went out of the garage to check, there is a tiny drop. I took a dry white paper towel to wipe, no green fluid, just black dirt. I took a flashlight to look and didn't see anything. Every hose, pipe, metal parts are dry. Like I said, I take my 997 in for checkup every quarter, it's complimentary, and I like to checkout new inventory on my dealer's lot. And every time the mechanic say my 997 is perfect. No leaks. etc.
#39
HI - has anyone ever figured out what the green watery fluid is ? I have the same - this is the second time now - in 2 months. Could it be related to road salt ? It is winter here with snow and ice. I tasted the fluid last time and it was salty. I did find some dried fluid on one exhaust pipe, so it does look like it is condensate - but the color is a nice clean florescent green. The first time I passed it off a some kind of animal pee. No reason to post pics, they are almost identical as the pictures above !
