View Poll Results: did YOUR car suffer an IMS failure
yes, the IMS failed
5.65%
No issues with IMS
94.35%
Voters: 1663. You may not vote on this poll
IMS failure for your 997 car, Y or N? tell us (yr, 997.1, .2, m96, m97, failure mode)
Old 12-27-2023 | 04:50 PM
  #1156
Charles Navarro's Avatar
Charles Navarro
Originally Posted by carguy999
Jeez seriously? Replace IMS every three years? What's the service cost for switching to the "forever" solution typically?
Takes between 10-14 hours to do the whole job. I've seen labor rates as low as $75/hr and up to and over $300/hr in metro areas.
carguy999 (12-28-2023)
Old 12-28-2023 | 06:42 PM
  #1157
carguy999's Avatar
carguy999
Thanks Charles. Do people need to certify to install, or could my local indy do it?
Old 01-03-2024 | 11:55 AM
  #1158
Charles Navarro
It is not required to use a certified shop to have your IMS Retrofit or IMS Solution fitted. Your local indy should be able to do it, just be sure to have them follow our guidelines including registration.
Old 09-02-2024 | 08:03 PM
  #1159
Charles Navarro
Originally Posted by tapper56
2nd owner 2006 997S with 24K. No IMS issues. Great car but oil comsumption more than my 1999 3.4 996 I owned. Great car!
No real reason to worry about 997 ims bearing failure with the non-serviceable intermediate shaft bearing on the 06-08 model years.
Just pull the grease seal off the original bearing when you go in to do the clutch next. That's all that you need to do (steps required to do so are provided in the above link).
groovzilla (09-02-2024)
Old 09-02-2024 | 10:11 PM
  #1160
Jim48's Avatar
Jim48
Default I have gotten your replacement
Thanks for the additional information Charles. At about 78,000 on my 2006 997.1 C2S (I'm the original owner), the dealer was telling me to get the IMS replaced with the "Porsche IMS." I would also have gotten the clutch replaced and probably had some bore scoring(had some symptoms when I was using cheap gas . As I still love the car, I decided to buy Jake Raby's FSI Stage II. Had it installed by a car restorer (at 79,127 miles) who cleared everything through Jake/FSI during the installation and also performed additional fixes. As a result, I have your LN IMS fix (IMSS54055) and your other fine components in my new engine. WORTH IT!!!
Quick Reply: IMS failure for your 997 car, Y or N? tell us (yr, 997.1, .2, m96, m97, failure mode)
