coolant cap
Old Apr 20, 2011 | 11:29 PM
997_rich's Avatar
997_rich
Default coolant cap
I changed my serpentine belt today after a spirited 4 hour drive (my work requires that I make 2 four hour drives every week). The belt change went off without a hitch.
However, I did notice a small amount of coolant around the coolant cap. I would say it was less than a half teaspoon of coolant. Has anyone noticed this? It was after some very sprited driving. Or is this a signal that I should replace the coolant cap? I did a search on coolant caps and it seems like they are prone to failure.
Old Apr 21, 2011 | 12:12 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
They are a very poor design--cheap insurance to replace. Cinch it down good when you put it on.
Old Apr 21, 2011 | 07:04 AM
McCulla's Avatar
McCulla
I may be wrong, but I seem to remember that there has been an update in the design of the cap. Make sure you get the "new" one.
Old Apr 21, 2011 | 07:58 AM
jhbrennan's Avatar
jhbrennan
Last one I purchased was v.4
Old Apr 21, 2011 | 08:57 AM
997_rich's Avatar
997_rich
how do I know that I'm ordering the latest one? I was just going to order part # 99610644704 from suncoast. Should I specify that i want a v.4?
997_rich's Avatar
997_rich
nevermind, I see in the details section of suncoast "this is the latest one available"
Old Apr 21, 2011 | 09:41 AM
Spiffyjiff's Avatar
Spiffyjiff
yep, i had a lot around mine (but i track in hot temps too) and bought a new one last yr. clean as a whistle so far.
Old Apr 21, 2011 | 09:52 AM
chsu74's Avatar
chsu74
That sound be the latest version ending on 04. They had a 01, 02 and 04. 03 was skipped.
Old Apr 21, 2011 | 12:56 PM
larrytrk's Avatar
larrytrk
Mine was replaced on my 06S when my car was 1 yr old because of the same crusty reason, none after that.
Old Apr 21, 2011 | 01:59 PM
CtrUSA's Avatar
CtrUSA
were newer models fitted with the v4 version? If so does someone know when that might've taken place. Seems like very cheap insurance, but if I have it already, no sense in messing with it.
Old Apr 21, 2011 | 09:27 PM
jhbrennan's Avatar
jhbrennan
IIRC, the number is on the cap so you can check to see if yours is the latest.
Old Apr 21, 2011 | 09:35 PM
997_rich's Avatar
997_rich
I have v1 for reference
Old Apr 24, 2011 | 11:56 AM
997_rich's Avatar
997_rich
I chopped up the old V .1 coolant cap and took a few pics for reference. It looks like it was not broken but it just must be some of the seals were getting old and couldn't hold up to the pressure.
from pulling it apart, the function of this thing is:
1. to easily let air into but not out of the system so when the car is shut off and the system is contracting it doesn't pull a vacuum. smaller spring and seal.
2. high pressure blowoff for safety. bigger spring and seal.
I'm not sure which seal was leaking -they both looked pretty good.
File Type: jpg
File Type: jpg
File Type: jpg
Old Apr 26, 2011 | 01:52 PM
yvesvidal's Avatar
yvesvidal
That's it. The temperature has suddenly risen to 85 degrees and a small whitish deposit was visible on the coolant cap. Mine is a V1 version (2006 C4S) and will need to be replaced.
Suncoast I presume.... because I hate to deal with my local dealer (Cary, NC).
Yves
