Anyone has experience with 997.1 Cat bypass pipe?
I am thinking of doing cat-bypass on my car.
The FVD cat bypass seems like to have the best of both worlds in terms of all cat-bypass options out there.
Description on FVD site:
Catalytic Bypass pipe “X Torque” design made by M&M in Germany.
The "X torque" design in is a true X pipe design. It is open in the center to add backpressure for torque. Give's you 10-15 ft-lbs of torque in the mid range along with 10-15 hp in the higher rpms. Why settle for the traditional cross over cat design when you can add torque in the mid range where the 997's need it most!!
I figure a cross-over (NHP)style cat bypass may loss too much torque in the mid range and a X type which mix up exhaust from both banks (like Fabspeed?) may not gain as much on top end.
Does anyone have first hand experience with any cat-bypass out there?
1st pic: FVD
2nd pic: Fabspeed
3rd pic: NHP
![](http://www.fvd.de/assets/adb/38/3857825e00d84035.jpg)
1st pic: FVD
2nd pic: Fabspeed
3rd pic: NHP
![](http://www.fabspeed.com/images/997_37_1.jpg)
Yes the cat-bypass is to be used as a track only setup, I know many has done AWE or Fabspeed 200 cell cat but I have searched the forum and seems like no one has try the cat-bypass.
Does the Fabspeed X-cats have an actual crossover in the middle which 2 exhaust banks merged or are they just welded together on the outside?
It is hard to tell from the picture since the name plaque blocks it.
