Porsche Acoustics
#31
My 996 was my first P car since my '87 911. I thought the sound was great. When I got the 997.1,
the sound was so much richer that I was sure I had PSE stuck on the open position. I later found out that
I was strictly stock
#32
I'm in it for the motor sound too. My .1 C2S stock exhaust sounds great to me otherwise.
#33
Seen many threads about pulling the plug in the engine bay to keep PSE on all the time. For the new GTS, there looks like there are two similar looking solenoids with vacuum hoses coming out. One in a similar position as previous posts picture show (fixed to side of intake manifold further in) and the other closer to the rear fixed onto the side plastic snorkel cover. None of them are orange/brown connectors anymore, both are black.
Which one is it to pull?
#34
#36
my experience as follws:
996.2 w/ PSE = very happy driver (me)
997.1 w/ PSE = happy driver, but longing for the angrier version of the 996.2
no experience w/ 997.2
#38
It can be done fairly easily. This has been widely discussed so a quick search should give you more details. Suncoast Porsche has good prices but your local dealer may be willing to match them. Expect to pay in the vicinity of $3500 for the parts and installation. This is a potential DIY project but be aware it involves taking apart sections of the interior and dash to install wiring and the control switch so you'll want to factor that into your decision on whether to tackle the job yourself.
#39
ok, have pulled the connector (you can see the brown tape) on my GTS. It definitely by-passes the switch on my console as pressing it does nothing now.
![Name: IMG_0324.jpg
Size: 135.2 KB](https://rennlist.com/forums/attachments/997-forum/530577d1303445646-porsche-acoustics-img_0324.jpg)
However, this is a picture of the 2nd Solenoid which has a similar connector and vacuum hoses. I confirm that those vacuum hoses also affect the PSE. If I leave the first Connector in place and pull the 2nd Solenoid's vacuum hose, it also affects the sound. Hence, they must both be connected to the PSE.
![Name: IMG_0326.jpg
Size: 94.8 KB](https://rennlist.com/forums/attachments/997-forum/530578d1303445646-porsche-acoustics-img_0326.jpg)
I did try to pull the 2nd connector as well. Am not very sure but I thought that the PSE sounded slightly louder at low speeds.
Anyone know what this second Solenoid is meant to do?
#40
Attachment 530577
Attachment 530578
Attachment 530577
Attachment 530578
#42
Poseur
The hardest part to adding PSE to a car is adding the wiring up to the console that will give you the control to turn it on and off from the seat. However, that's one of the great features of PSE.
#43
Miserable Old Bastard
Ignore - oops, just realized I already posted in this thread!
#44
Interesting. The plug you show in your first photo appears to be the same one I pointed to in my picture above. When I pull that plug, not only does the switch not function any more, but the exhaust goes into "loud mode" (just like when everything is hooked up and the PSE switch is activated) and stays there. I've never tried pulling the other plug and don't know what it's for.
#45
Since pulling the first plug has the desired result (PSE on all the time) I never felt the need to experiment further or disconnect anything else. If you figure out what the second plug does let us know.
