Ball park cost to lower?
The last car I had done was my '96 C4S and I got the ROW M030 kit from Porsche to have it done, along with an alignment and corner balance (?), and I seem to remember about $2500, complete, done at Bob Hindson in KC. I know there are a bunch of ways to go with suspension changes, but I'm wondering about a similar set up to that ROW I had. Anyone have estimates of what it runs today, or are the options just too broad to throw a single figure out? Thanks.
A: Coilovers
2000-3000 (depending on brand)
300 Labor*
100 Alignment*
=2400-3400 total
B: Springs
300-400 (depending on brand)
300 Labor*
100 Alignment*
=700-800 Total
also then figure labor to uninstall and align when you sell/change mind.
the Δ between the two personally sways me to coilovers (if you dont have PASM) as they are adjustable to make them exactly how you want.. and the cost of labor/align is the same as springs and you can always overhaul them and sell when done..
i voted coilovers on both my 997's. (KWv3)
for PASM equipped cars, you need damptronics to utilize the PASM, otherwise get a light or have to go to dealer for additional cost to turn off the PASM using PWIS.
with springs your PASM will still work fine, but shocks could blow with extended use on springs (more load on shocks at all times).
-Riley
*Labor rates will vary wherever you are.... (where in florida are you located? i could recommend a place in Tampa)
*Install i have seen as cheap as $250, and as much as $1000
*Alignment i have seen as cheap as 80$ and as much as $300
300 Labor*
100 Alignment*
=2400-3400 total
B: Springs
300 Labor*
100 Alignment*
=700-800 Total
-Riley
Prices:
Coilovers:
KWv3 ($2500 on TireRack)
H&R ($1850 on TireRack)
Bilstein PSS9 ($3100 w/ PASM, $2800 w/o PASM on TireRack)
Springs:
H&R $315 (TireRack)
Eibach $323 (TireRack)
i had KWv3 on both my 997.1 and 997.2 (had problems both sets with the rear shocks, both taken care of promptly by KW but honestly i always wanted to try the H&R kit because it gets good street reviews but bad track reviews)
Coilovers:
Springs:
H&R $315 (TireRack)
Thank you kindly for the detailed information! I don't have PASM and realized after I posted originally that I left out any stats about the way I use my car. It is my daily driver, no track, and I don't really care about ride. I'm looking primarily for improved appearance (in my eyes) with relatively equivalent wear/tear on suspension components and tires. I'm in Gainesville, but would sure appreciate your Tampa recommendation. Thanks again.
i personally would suggest the H&R @ 1850 for a street coilover, the people that complain track the coil and those that like it are daily drivers.. it is said to be forgiving yet quality... my shop local always does the install for the rates i listed.. which is very affordable compared to the dealer/etc.
the KW were more track oriented IMO.
springs are cheaper alternative, BUT the OEM shocks could blow and then cost becomes the same...
Yeah, I guess I sort of made the assumption that these set ups would probably be a handling gain, and didn't mean to neglect that aspect as one of my aims with lowering. By the way, would you mind sharing the name of your Tampa shop? Thanks again.
i am taking my exige there next week to change the pulley on my supercharger and get an oil change and some other misc.
Great! I recall a recent thread, I believe, where you mentioned this shop. I can find it easily. Thanks for the info and letting me use you as a referral. Patrick
I think that lowering a 997 for appearance only is misguided, but it is your car. Be forwarned that there are several issues that you need to consider:
-Whether coilovers or shorter & stiffer springs, the ride will be significantly harder.
-The car has ground clearance problems in stock condition. Lowered is worse. Be prepared for the air dam and brake ducts striking pavement in situations you can't avoid.
-The suspension has limited adjustment. Negative camber in the rear is likely, with appearance issues and increased tire wear.
The saving grace is that this modification is reversible.
Michael, as I'd mentioned, I've owned and driven (6 years) a lowered 993 so I'm aware of the issues you've raised. If that places me in your "misguided" category, so be it. Personally, I am a fan of the lower appearance and if handling is improved, so much the better.
