Remote stopped working...
Old Aug 21, 2020 | 12:39 PM
  #61
gmorat's Avatar
gmorat
Lock the doors from the outside by using the key in the door lock.
Unlock the drivers side door using the key in the door lock.
Within about 10 seconds or so, open the door and insert the key into the ignition. DON'T START THE CAR!!
With the key still in the ignition, push the unlock button on the key.
Voila, you should be good to go.
This just worked for me in a 2009 Cayman S when none of the other procedures did! Many thanks!
G
Old Aug 21, 2020 | 12:47 PM
  #62
IrishLegend's Avatar
IrishLegend
Thanks! I'll try when I get home.
Old Oct 15, 2020 | 07:21 PM
  #63
Chris L's Avatar
Chris L
Originally Posted by DHC
I had the same issue and also tried every iteration possible to get my keys to re-sync. The manual is not very helpful, but I finally stumbled on this approach, which worked great for me:
Another successful fix using this method. I had a new key 2 programmed by the dealer and key 1 stopped working as a remote (worked fine in the ignition). Tried this and now both are working perfectly.
Chris.
Old Dec 29, 2020 | 10:15 AM
  #64
eclou's Avatar
eclou
Yassss!! Sage advice!!
Old Aug 20, 2021 | 09:48 AM
  #65
gbworks's Avatar
gbworks
Worked for me!!
